ford-boy Posted July 7, 2019 Share Posted July 7, 2019 Just below the climate controls, there is a storage cubby that has a horizontally sliding door. There is a small light inside that seems to stay on as long as the sliding door is pushed open. Is this normal? If the door is open and you lock the vehicle, set the security, the light will NOT go out. If you are only using the vehicle during the day, you will NEVER know there is a light on inside the cubby. If the vehicle is left for 2 weeks or so, possible dead battery? Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted July 8, 2019 Share Posted July 8, 2019 43 minutes ago, ford-boy said: Just below the climate controls, there is a storage cubby that has a horizontally sliding door. There is a small light inside that seems to stay on as long as the sliding door is pushed open. Is this normal? If the door is open and you lock the vehicle, set the security, the light will NOT go out. If you are only using the vehicle during the day, you will NEVER know there is a light on inside the cubby. If the vehicle is left for 2 weeks or so, possible dead battery? Have you checked it after the vehicle is undisturbed for 10 mins or so? The battery saver kicks in after 10 mins. Quote Link to comment Share on other sites More sharing options...
ford-boy Posted July 8, 2019 Author Share Posted July 8, 2019 OK. I will try that. Quote Link to comment Share on other sites More sharing options...
