Bronco mule
Powertrain mule. The first actual Bronco bodies are scheduled to be built at the pilot plant sometime in April.
Fun Fact: that rail line feeds the Rouge complex. Those cement arches are relics of the old DT&I railroad from when Henry Ford owned it. They were built during his experiment with electrifying the line but the powerhouse couldn't keep up with the electric demands a fully loaded train needed and the project was abandoned. The arches remain because they were so well overbuilt it was determined it was unnecessary and too expensive to tear them down.
Edited by fuzzymoomoo
This actually got me excited seeing this. Confirms that they are definitely going ahead with the 2 door version of new Bronco. Heard some rumors that either only few 2 doors will be made or have been canceled. I already know what a mule is and why they did the Ranger cab and short bed of it. Makes sense that it's a powertrain test and will do Bronco trial body later.
I expect the mix of 2 door Bronco to eventually be similar to that of the Wrangler.
And by the way, that's just current Ranger body work made to fit the future Bronco chassis,  looks like Watts Link in the rear, hopefully outboard shocks like on Ranger Raptor.. cant wait to see the four door version...oops
Also, that  little cover at the back most likely covers the rear skeleton of the two door Bronco, so maybe a clue to the rear shape?
Edited by jpd80
Oh I didn't think they would do the 2 door/4 door ratio of that similar to the Wrangler but that does makes sense. I figured the 2 door would be much less and pretty much marketed for the purists while the 4 door being made as mainstream Bronco model. But you may be right on that regarding the similarity of Wrangler 2 door/4 door ratio.
I suspect that both will look similar, the two door having a similar space behind the door as the mule and the four door being a longer wheelbase and body
Those tail lights are also... not Ranger
10 minutes ago, Anthony said:
Front is definitely IFS for anyone thinking they were actually going to stick an SFA up there.
Curious what type of suspension is hiding behind those brushes in the back.
Some of the shots from the rear seem to show a set of control blades below the axle suggesting IRS. I'll reserve judgment for when I see better pictures
10 minutes ago, atomcat68 said:
I guess the take away from this may be that it is small and more true to the original Bronco than the "OJ" Bronco. This makes me happier.
After all, if they had to cut that much off a Ranger, to get this mule to fit, it has to be somewhat small.
I hate to keep making this comparison but My best guess is it is similar in size to the Wrangler.
People forget just how small the 66-77 Bronco was. The 77 on was HUGE. Officially the Expedition was it's replacement FFS.
Keep it more contenpary-
The 75 Bronco was the size of an Ecosport
The F-series based one was the size of an Escape.
I shit you not.
