steelerfeever Posted February 12, 2019 Share Posted February 12, 2019 My rear seat entertainment headphones walked off (stolen). I called the dealer and they quoted $500-550 "because they come in a kit". With no aux input are there compatible, less expensive options for my kiddos? Quote Link to comment Share on other sites More sharing options...
fordmantpw Posted February 12, 2019 Share Posted February 12, 2019 Yes, you should be able to buy a pair almost anywhere. We got the pair below off Amazon and they work fine in our Flex. Probably as good if not better than the originals. https://www.amazon.com/gp/product/B001P3PSS0/ref=oh_aui_search_asin_title?ie=UTF8&psc=1 Quote Link to comment Share on other sites More sharing options...
steelerfeever Posted February 13, 2019 Author Share Posted February 13, 2019 Thanks. I'm not sure the Flex has the same rear seat entertainment setup that the new Navigator's have though. Quote Link to comment Share on other sites More sharing options...
LHB Posted February 13, 2019 Share Posted February 13, 2019 This uTube video review mentions he checked that the headphones were ~$50. I found the review very interesting considering all the negative comments I’ve been seeing. Quote Link to comment Share on other sites More sharing options...
fordmantpw Posted February 14, 2019 Share Posted February 14, 2019 13 hours ago, steelerfeever said: Thanks. I'm not sure the Flex has the same rear seat entertainment setup that the new Navigator's have though. They likely are. That's not a technology that's likely to change often. Quote Link to comment Share on other sites More sharing options...
remaza Posted February 3, 2020 Share Posted February 3, 2020 Any update on above , where can we order the 2019 LINCOLN NAVIGATOR extra headphone and remote, and how much is it? Does any one know? Thanks in advance. . . Quote Link to comment Share on other sites More sharing options...
remaza Posted February 3, 2020 Share Posted February 3, 2020 Any suggestions? Thank you Quote Link to comment Share on other sites More sharing options...
musiccitybugs Posted February 4, 2020 Share Posted February 4, 2020 I bought these as replacements for the lincoln headphones, they work great for kids, maybe a little more background hiss, but they didn't notice. Much cheaper than what Lincoln charges. https://www.ebay.com/itm/142788661499 Quote Link to comment Share on other sites More sharing options...
AKentPhoto Posted February 10, 2020 Share Posted February 10, 2020 Personally I plan on going the bluetooth route. This also allows 2nd row people to use the factory headsets while the 3rd row can enjoy the audio as well. It also allows for much higher quality (even noise canceling) headphones. I will have to do some research on latency but the newer versions of BT are suppose to be better at that. These transmitters also allow for connecting two sets of headphones at the same time. I have one that has a battery and I use it on long flights with my wife so we can watch movies together and it works flawlessly. I can even go to the bathroom on the plane without losing signal. This one seems well setup for our application. https://www.amazon.com/Bluetooth-Transmitter-Receiver-Goojodoq-Non-Bluetooth/dp/B07VYYS28K/ref=sr_1_41?keywords=bluetooth+transmitter+portable&qid=1581368429&sr=8-41 Quote Link to comment Share on other sites More sharing options...
snarbles Posted January 20, 2022 Share Posted January 20, 2022 I am looking for a replacement set that is IR and has the A/B selector as well since the bluetooth option only works with one headset. The dealer says they do not currently have any in stock. Does anyone know the frequency that the 2019 headphones transmit over? These IR headsets on Amazon say the work over: A Channel L/2.3MHz R/2.8MHz B Channel L/3.2MHz R3.8MHz SIMOLIO 2 Pack of Wireless Car Headphones, 2 Channel IR Wireless Headphones for Kids, in Car Wireless DVD Headphones with Storage Bag for Universal Rear Entertainment System, Not for 2017+ Pacifica https://www.amazon.com/Wireless-Headphones-Travelling-Universal-Entertainment/dp/B079CKQR4N/?_encoding=UTF8&pd_rd_w=IIkY8&pf_rd_p=29505bbf-38bd-47ef-8224-a5dd0cda2bae&pf_rd_r=MQPNTMQAR5XYFANQEQY6&pd_rd_r=b3ea922c-646b-488f-9ba2-58553d11ef02&pd_rd_wg=1wysd&ref_=pd_gw_ci_mcx_mr_hp_atf_m&th=1 If the Lincoln works over this frequency then these might work. I might give them a try and let you know, but I'm concerned that my Lincoln 2019 Navigator L may use a proprietary frequency. Having a separate channel per screen seems ideal. Quote Link to comment Share on other sites More sharing options...
