MTC57 0 Report post Posted February 8 Has anyone had problems with not being able to completely fill the gas tank on the 2018 Edge Sport? My gauge will show that I have less than 50 miles to empty but the tank will only take 12 to 13 gallons in a 18.5 gallon tank. The gas will shoot out of the capless fill and puddles underneath. Even though I clean it up immediately, the gas smell doesn't go away. I never had a problem with my 2011 Limited. Share this post Link to post Share on other sites
akirby 7,325 Report post Posted February 8 First you should never fill it past the first or second click. You can damage the vapour canister. Depending your average mpg it sounds normal. Even at 0 miles to empty there will still be up to a couple of gallons in the tank as a reserve. Share this post Link to post Share on other sites
fuzzymoomoo 2,914 Report post Posted February 8 21 minutes ago, akirby said: First you should never fill it past the first or second click. You can damage the vapour canister. Depending your average mpg it sounds normal. Even at 0 miles to empty there will still be up to a couple of gallons in the tank as a reserve. 6 gallons extra? That seems very excessive Share this post Link to post Share on other sites
fordtech1 487 Report post Posted February 8 You said 50 miles to empty. What’s the actual gauge show? 1/4 or 1/8th of a tank? Distance to empty can be skewed from excessive idling. If it’s way off. Disconnect the battery and retest. That will reset DTE and averages. Share this post Link to post Share on other sites
Anthony 1,338 Report post Posted February 8 Have not had that issue on our 18 Edge. Share this post Link to post Share on other sites
