New Facebook Pages
Ford Mach E
Ford Thunder
  • 0
Banger13
2007 Lincoln navigator
Question
I have a 2007 navigator replaced engine it has 220k.   Now the code is saying cam phaser but we recently replaced when we changed the engine.   And it runs really rough  but we can unplug then from the  soleniod and it runs smooth but the check engine light is on.   The mechanic thinks it's the solenoid or the computer.   Any suggestion.
1 answer to this question
  • 0
IF the HOT oil pressure has been verified as over 20 psi in gear at idle, then switch the solenoids from bank to bank. IF the problem follows the solenoid, its the solenoid. If it stays on the same bank, most likely a phaser or base timing issue. Just because it is new, doesn't mean it is good, and there are more issues with aftermarket parts than the Ford ones.
