my front blower doesn't blow any air at any speed, any ideas
stretches flex
Check fuse 35 under the hood. What I would do First is disconnect the connector to blower motor. Put a test light or use a tail lamp bulb and use that as the load and see if they illuminate when you turn blower on high. If not, without proper diag I would guess at a blower speed controller. Does the ac control head light up and seem to respond?
If you have a test light, check for power on yellow and green wire at two pin blower motor connector with key on. If no power then we need to look back at fuses and relays. If you have power do what I recommend with the light bulb in blower motor connector to substitute the blower with a bulb. That will check power and ground. If it illuminates then the motor is bad.
  • 3 weeks later...
