DCP Posted September 15, 2018 Share Posted September 15, 2018 Anyone know how to turn on the constant power in the 7 pin connector? Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted September 16, 2018 Share Posted September 16, 2018 Not sure what year navigator you are talking about but there is a fuse and relay that went in the underhood fuse panel for that. It used to come in glove box in plastic bag. Quote Link to comment Share on other sites More sharing options...
DCP Posted September 16, 2018 Author Share Posted September 16, 2018 Not sure what year navigator you are talking about but there is a fuse and relay that went in the underhood fuse panel for that. It used to come in glove box in plastic bag. It's a 2018. Nothing provided and the list of fuses wasn't helpful. Thanks for the comment. Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted September 16, 2018 Share Posted September 16, 2018 (edited) Check #30 fuse in the under hood fuse box its a 25 amp. Its lists as the trailer tow charge fuse which would be power to the 7 pin connector. I dont have access to shop Manual at the moment but thats out of the owners manual. Edited September 16, 2018 by fordtech1 Quote Link to comment Share on other sites More sharing options...
DCP Posted September 16, 2018 Author Share Posted September 16, 2018 Check #30 fuse in the under hood fuse box its a 25 amp. Its lists as the trailer tow charge fuse which would be power to the 7 pin connector. I dont have access to shop Manual at the moment but thats out of the owners manual. Thanks. I checked that because adding a fuse was what I had to do in my last Suburban. In the Navigator there was a fuse there already, but no power in the 7 pin harness so there must be something more you have to do. Quote Link to comment Share on other sites More sharing options...
theoldwizard Posted September 17, 2018 Share Posted September 17, 2018 The best wiring diagram I can find is from 2017, but I think it is the same. The power wire is orange. The battery tow module MAY have smarts in it to not power up that pin until it "senses" that a trailer is attached (tail light bulb resistance ?) Quote Link to comment Share on other sites More sharing options...
DCP Posted September 17, 2018 Author Share Posted September 17, 2018 The best wiring diagram I can find is from 2017, but I think it is the same. capture.jpg The power wire is orange. The battery tow module MAY have smarts in it to not power up that pin until it "senses" that a trailer is attached (tail light bulb resistance ?) Thanks, but it isn't that smart. On my trailer, that circuit powers loading lights. When I plug in the trailer, the tail lights and signals all work, but the loading lights circuit is dead. I plugged the trailer into my Suburban and the loading lights worked, so there is something needed in the truck to energize the circuit. Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted September 17, 2018 Share Posted September 17, 2018 Out if the WSM. TRM provides voltage to trailer battery charge pin after the following is met TRM detects trailer is connected ignition is on and engine running a brake application has been detected in the present ignition cycle a BCM load shed strategy is not active.. ( a message will be displayed in cluster. IE Low battery, battery save TRM directly supplies power for trailer battery charging no relay. 1 Quote Link to comment Share on other sites More sharing options...
DCP Posted September 17, 2018 Author Share Posted September 17, 2018 Out if the WSM. TRM provides voltage to trailer battery charge pin after the following is met TRM detects trailer is connected ignition is on and engine running a brake application has been detected in the present ignition cycle a BCM load shed strategy is not active.. ( a message will be displayed in cluster. IE Low battery, battery save TRM directly supplies power for trailer battery charging no relay. Wow. Thank you. I needed to apply the brakes after connecting the trailer to make it work. I never would have guessed that. Quote Link to comment Share on other sites More sharing options...
tobe Posted September 21, 2018 Share Posted September 21, 2018 That is really helpful, thank you Quote Link to comment Share on other sites More sharing options...
Boz Posted August 6, 2021 Share Posted August 6, 2021 Wow great information on this pin 4 power. I am installing a Tekonsha Prodigy RF Wireless Trailer Brake Controller w/ Bluetooth - 1 to 3 Axles - Proportional controller… It requires the 12V on pin 4 to function.. So it looks like I get the power once all hooked up and the brakes are applied, which is easily done as you have to hit the brake to both start the car and to shift the transmission… So I should be good to go.. Thanks for the information supplied almost 2 years ago… Google is our friend!! Quote Link to comment Share on other sites More sharing options...
