New Facebook Pages
Ford Mach E
Ford Thunder
silvrsvt
Ford recalling 2 million F-150 for seatbelt issues
Ouch
http://www.autonews.com/article/20180906/OEM11/180909864/ford-recalls-two-million-pickups-f150
So who pays for this? Ford or the subcontractor who made them?
In this case it should fall squarely on the supplier unless it was somehow related to something Ford asked for (doubtful in this case). Of course Ford has to pay its dealers for the repairs first then get reimbursement from the supplier if they can.
From what Ive read this morning, This recall will just be some shielding and insulation rework.
Actually the recall is out and no special parts. Basically they are removing or covering anything that could be ignited next to the discharge side of the pretensioners.
Edited by fordtech1
Yep. Remove any foreign debris, certain insulation and tape up the area. I think it is more of a "whoops we put somewhat flammable insulation next to an ignition source". So far there is a lot of scuttlebutt about build sheets and other foreign materials in the areas too.
This does not surprise me. Ive heard of this happening if trim pieces arent fitting properly, and management turns a blind eye in order to keep their almighty production numbers instead of fixing the problem. This was a huge thing with the headliners of early FRAP built Fusions, balls of paper (build sheets) in select spots were used to keep the headliners from coming loose and flopping around.
My F-150 was built on 9/4/18. Will I have an issue?
I would have to assume they knew about the issue, so therefore wouldn't equip new builds with it. But you never know I guess.
If it did, it would be held until the recall repair could be performed, but I would expect that it would've been built with the fix already implemented.
