fuzzymoomoo Posted August 12, 2018 Share Posted August 12, 2018 (edited) Evaporative Emission System Switching Valve Performance or Stuck OpenFriend of mine has his car throwing this code. Where is this switch located? I want to try and fix it for him when hes in town next weekend. Forgot to add: 1.5 EcoBoost engine. Edited August 12, 2018 by fuzzymoomoo Quote Link to comment Share on other sites More sharing options...
YT90SC Posted August 13, 2018 Share Posted August 13, 2018 (edited) FIRST even though the code does not specify, check the Evap purge valve/ejector assembly at the engine. They LOVE to fail and can set the P2450, regardless of what the code definition says. The blocking valve will be between the fuel tank and canister in the EVAP lines, and have two wires one green, the other grey with a violet tracer. Base number is 9D333. Edited August 13, 2018 by YT90SC Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted August 13, 2018 Author Share Posted August 13, 2018 Where on the engine is that? I have a very limited time to fix this Thursday before he drives back to Ohio Quote Link to comment Share on other sites More sharing options...
YT90SC Posted August 14, 2018 Share Posted August 14, 2018 There are two lines that come from the rear of the car near the firewall. One is the fuel line, the other is the vapor line. The one that comes up and doesn't split and connects to he HPFP is the fuel line. The other is the purge valve/ejector assembly. It leaves the steel from the rear and connects in a couple spots on the intake with quick connects. I I am fairly sure no special tools will be needed to change it. Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted August 14, 2018 Author Share Posted August 14, 2018 Is this it? https://www.rockauto.com/en/catalog/ford,2016,fusion,1.5l+l4+turbocharged,3330859,exhaust+&+emission,vapor+canister+vent+valve+/+solenoid,16992 Quote Link to comment Share on other sites More sharing options...
YT90SC Posted August 14, 2018 Share Posted August 14, 2018 No. The ones you have highlighted are the VENT solenoid. The one above those in the link you sent is the PURGE/ejector assembly. Its the funny hose looking thing with multiple connections. I don't see the blocking solenoid on there. Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted August 14, 2018 Author Share Posted August 14, 2018 Sounds like this might take longer to diagnose and fix than the amount of time I have to do it Ill just tell him to take it to the dealer. Quote Link to comment Share on other sites More sharing options...
YT90SC Posted August 15, 2018 Share Posted August 15, 2018 Without proper two way scan tool, it could be hard. If I was betting in Vegas, I'd say purge assembly. You COULD take the hose off at the steel line near the firewall and suck on it (plastic part). If it doesn't hold, it needs the purge assembly. Not being able to operate the blocking valve with a scan tool puts you at a disadvantage to completely diagnose it. Quote Link to comment Share on other sites More sharing options...
