Custom Search
Welcome to Blue Oval Forums
Sign In  Log in with Facebook
Create Account
Guest Message by DevFuse
Hid lights
  • Please log in to reply
3 replies to this topic
#1 OFFLINE   Jolokken13
Jolokken13
    New BON Member
  • Blue Oval Member
  • Pip
  • 3 posts
  • Joined 10-August 18
  • Region:U.S. Great Lakes
  • Current Vehicle:Navigator
Posted 11 August 2018 - 01:53 AM
2011 navigator with HID lights. They keep shutting off. You can turn the switch off and turn it back on lights will come on for 2 min and then passenger will go out 2 sec later driver will go out? Im lost
#2 ONLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,753 posts
  • Joined 31-December 06
  • Region:Decline
  • Current Vehicle:2012 Ford Fusion SEL, 2007 Volvo C70, 2006 Mercury Mariner Hybrid, 2005 Ford Focus
Posted 11 August 2018 - 06:41 AM
I dont recall any service bulletins for that concern. Also, I havent seen that issue. I have seen that happen and had to replace the headlamp ballast. However, both headlamps defective at the same time seems less likely. Did this just start one day? Does it happen every time you use the headlamps? Not just in auto mode but in manual mode? Also is the engine running when this happens. The battery in the vehicle start the engine ok without any slow cranking? Battery voltage that is low will cause those lamps to shut off.
Edited by fordtech1, 11 August 2018 - 06:43 AM.
#3 OFFLINE   Jolokken13
Jolokken13
    New BON Member
  • Blue Oval Member
  • Pip
  • 3 posts
Posted 11 August 2018 - 06:44 AM
One had been doing it occasionally now they both are non stop. Battery is fine so maybe it is the bulbs
#4 ONLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,753 posts
  • Region:Decline
Posted 11 August 2018 - 06:50 AM
Chances are its the bulb or ballast. You can replace the bulb from a parts house, get a quality name like sylvaina .Start with one, if it fixes it then replace the other. Im sure the bulb is cheaper than the ballast.
Custom Search
