Custom Search
Welcome to Blue Oval Forums
Sign In  Log in with Facebook
Create Account
Guest Message by DevFuse
2001 4R70W slips in first gear but not in manual first
  • Please log in to reply
1 reply to this topic
#1 OFFLINE   spowel4
spowel4
    New BON Member
  • Blue Oval Member
  • Pip
  • 1 posts
  • Joined 01-August 18
  • Region:Decline
  • Current Vehicle:2001 Expedition
Posted 01 August 2018 - 08:46 AM
Like the title says, I have a 2001 Expedition, 2WD, 4.6L engine, with a 4R70W. When in Drive, the tranny slips when starting out from a dead stop. However if I put it into manual first gear, no slippage. Any suggestions on what might be going on?
#2 OFFLINE   YT90SC
YT90SC
  • Blue Oval Member
  • PipPip
  • 825 posts
  • Joined 28-July 04
Posted 01 August 2018 - 05:41 PM
In Drive 1 only the FORWARD clutch is applied. In manual 1, the LOW/REVERSE band is applied as well as the FORWARD clutch, but all it does is make it so the OWC can't free wheel on coast. There are several potential causes.
1. EPC solenoid is getting lazy and not following the increase in throttle pressure.
2. Forward clutch circuit is failing or clutch itself is.
3. Bolt backout in the valve body.
4. Several potential internal valve body issues.
That being said, are you 100% sure the PCM is commanding and achieving first gear and not actually in a higher gear? Any codes? IS the T/R sensor adjusted right and operating properly? Does it make all 3 shifts and lockup the converter? For example, if SSA is stuck off, you wont get first or fourth. If SSB is stuck on you won't have first or 2nd. Starting in a higher gear can seem like its slipping.
Dad always said,"Knowledge is limited but stupidity knows no bounds."
Custom Search
