vee_eye Posted June 25, 2018 Share Posted June 25, 2018 Thank you all for the wealth of information here. I am considering a 2019 MKC. The Lincoln website and the order guides here say the headlamps are LED. However, the window stickers of all 2019s available at 2 local dealerships says they all have HID headlamps with LED signature lighting. And the ones I saw in person didn't seem to have LEDs and looked same as 2018 HIDs. Any thoughts on which one is correct? Or are the LED to be added later in the model year? 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted June 25, 2018 Share Posted June 25, 2018 That's a headscratcher. All of the window stickers (Select, Reserve, Black Label) show HID but both versions of the order guide say Fixed LED. I would lean towards LED and the window sticker has a typo but the only way to be sure is to look at them in person and/or get a dealer to ask Ford. Quote Link to comment Share on other sites More sharing options...
rperez817 Posted June 25, 2018 Share Posted June 25, 2018 2019 MKC uses LED headlamps on all grades. Below is the link to the vehicle's bulb specification chart. MKC uses LED for all exterior lighting except front turn signal indicators and license plate lamps. http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O40549&languageCode=EN&marketCode=US&viewTech=IE&chapterTitleSelected=G1619316&subTitleSelected=G1949239&topicHRef=G1949240&div=l&vFilteringEnabled=False&userMarket=USA 1 Quote Link to comment Share on other sites More sharing options...
mkx_wanders Posted June 25, 2018 Share Posted June 25, 2018 Hmmm...This Order Guide has no changes to the headlights from HIDs http://www.blueovalforums.com/forums/index.php?/files/go/30b0bce3427a2058c337c258b18b9b52/2019-lincoln-mkc-order-guide Quote Link to comment Share on other sites More sharing options...
akirby Posted June 25, 2018 Share Posted June 25, 2018 Hmmm...This Order Guide has no changes to the headlights from HIDs http://www.blueovalforums.com/forums/index.php?/files/go/30b0bce3427a2058c337c258b18b9b52/2019-lincoln-mkc-order-guide Not sure which link you're using(doesn't work for me) but this is what is shown in the 2019 MKC order guide (both versions): Here is the correct link to the order guides: http://www.blueovalforums.com/forums/index.php?/files/go/92cfce9a81507369ba938e71c0afc216/2019-lincoln-mkc-order-guide Quote Link to comment Share on other sites More sharing options...
mkx_wanders Posted June 25, 2018 Share Posted June 25, 2018 Not sure which link you're using(doesn't work for me) but this is what is shown in the 2019 MKC order guide (both versions): Capture.JPG Here is the correct link to the order guides: http://www.blueovalforums.com/forums/index.php?/files/go/92cfce9a81507369ba938e71c0afc216/2019-lincoln-mkc-order-guide Ahhh...I was going off the Major Features Page. Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted June 25, 2018 Share Posted June 25, 2018 Ahhh...I was going off the Major Features Page. uh, that says highlights, not headlights.... Quote Link to comment Share on other sites More sharing options...
vee_eye Posted June 25, 2018 Author Share Posted June 25, 2018 Thanks everyone for the quick replies. I will go back to the dealership to check in person and ask them clarify with Ford as well. The same same owner manual @rperez817 mentioned above make no mention about LED headlamps under Maintenance section http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O40549&languageCode=EN&marketCode=US&viewTech=IE&chapterTitleSelected=G1619273&subTitleSelected=G1619294&topicHRef=G1623963&div=l&vFilteringEnabled=False&userMarket=USA And the so is the 2019 Owner's Manual version 1 PDF. Quote Link to comment Share on other sites More sharing options...
rperez817 Posted June 25, 2018 Share Posted June 25, 2018 Thanks everyone for the quick replies. I will go back to the dealership to check in person and ask them clarify with Ford as well. The same same owner manual @rperez817 mentioned above make no mention about LED headlamps under Maintenance section http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O40549&languageCode=EN&marketCode=US&viewTech=IE&chapterTitleSelected=G1619273&subTitleSelected=G1619294&topicHRef=G1623963&div=l&vFilteringEnabled=False&userMarket=USA And the so is the 2019 Owner's Manual version 1 PDF. You're welcome vee_eye sir. It's weird that the owner manual makes reference to both HID and LED headlamps. In the PDF Owner's manual, the bulb specification chart on page 354 says headlamps use LED. But page 300 says HID. Plus there's confusion with what the order guide and window sticker says as others have mentioned. The press release for 2019 MKC says the following. "The 2019 Lincoln MKC exemplifies the refined new face of Lincoln. The signature grille evokes a sense of confidence, and beautifully detailed LED headlamps illuminate the road with crisp lighting designed to minimize eyestrain." https://media.lincoln.com/content/lincolnmedia/lna/us/en/products/crossovers---suvs/mkc/2019-lincoln-mkc.html Let us know what you find at the dealership vee_eye. Hopefully this mystery can be solved! Quote Link to comment Share on other sites More sharing options...
vee_eye Posted June 25, 2018 Author Share Posted June 25, 2018 You're welcome vee_eye sir. It's weird that the owner manual makes reference to both HID and LED headlamps. In the PDF Owner's manual, the bulb specification chart on page 354 says headlamps use LED. But page 300 says HID. Plus there's confusion with what the order guide and window sticker says as others have mentioned. The press release for 2019 MKC says the following. "The 2019 Lincoln MKC exemplifies the refined new face of Lincoln. The signature grille evokes a sense of confidence, and beautifully detailed LED headlamps illuminate the road with crisp lighting designed to minimize eyestrain." https://media.lincoln.com/content/lincolnmedia/lna/us/en/products/crossovers---suvs/mkc/2019-lincoln-mkc.html Let us know what you find at the dealership vee_eye. Hopefully this mystery can be solved! @rperez817, I will. Good to know the press release has LED headlamps mentioned which can show the dealer. 1 Quote Link to comment Share on other sites More sharing options...
vee_eye Posted June 27, 2018 Author Share Posted June 27, 2018 @rperez817, I will. Good to know the press release has LED headlamps mentioned which can show the dealer. Dealer said Ford confirmed headlights are HID with LED signature lights. He also showed me presumably an updated order guide with the same information. If that is just for Canada I am not sure but I highly doubt that these features differ between US and Canadian versions. It is a little disappointing considering some mainstream vehicles in this category like Chev Equinox, Toyota RAV4, Honda CRV, GMC Terrain all offer LED headlights as an option. 1 Quote Link to comment Share on other sites More sharing options...
rperez817 Posted June 28, 2018 Share Posted June 28, 2018 Dealer said Ford confirmed headlights are HID with LED signature lights. He also showed me presumably an updated order guide with the same information. If that is just for Canada I am not sure but I highly doubt that these features differ between US and Canadian versions. It is a little disappointing considering some mainstream vehicles in this category like Chev Equinox, Toyota RAV4, Honda CRV, GMC Terrain all offer LED headlights as an option. Thank you vee_eye sir for checking with your dealership. IIHS said the HID headlamps for 2017 MKC illuminated a good distance, but also that it produced excessive glare for other motorists. http://www.iihs.org/iihs/ratings/vehicle/v/lincoln/mkc-4-door-suv/2017#other-model-years 1 Quote Link to comment Share on other sites More sharing options...
vee_eye Posted June 28, 2018 Author Share Posted June 28, 2018 Thank you vee_eye sir for checking with your dealership. IIHS said the HID headlamps for 2017 MKC illuminated a good distance, but also that it produced excessive glare for other motorists. http://www.iihs.org/iihs/ratings/vehicle/v/lincoln/mkc-4-door-suv/2017#other-model-years Most welcome! And thank you too for the IHS ratings page. 1 Quote Link to comment Share on other sites More sharing options...
