2010 fusion won’t start or run with maf plugged in
Chrishayle
I swapped maf sensor yesterday thinking that it was gonna be my problem because my car will only run with maf disconnected. It was giving me p0102 and p0113 codes . However this did not fix my problem. Im thinking i may possibly have a connector or wiring issue with the maf sensor plug. Anyone have any suggestions?
Edited by Chrishayle
Could be either. The 2010 models had some issues with the harness running under the battery tray and chafing or corroding. I have see connector pins damaged and also have seen leaves get into the Maf causing no starts. With out seeing pid data its hard to say. I would check all these things first.
Can you see the engine cylinder head temp sensor? I had a 2010 that was doing weird stuff the temp gage was a little erratic. Ended up being CHT sensor wiring. Was reading super cold and freaking out the pcm. Was dumping fuel to try and make it run.
