flagman Posted April 21, 2018 Share Posted April 21, 2018 Long time Ford and Lincoln owner, currently own an 18 Navigator Select and 17 Raptor. I programmed the Raptor third key fob easily as the manual directed, having two fobs, but the third fob for the Navigator fails. I've tried 6 times, doing exactly as the Navigator owners manual says. Can anyone offer any insight as how to do this correctly, the manual says its possible with two fobs, thanks in advance, flagman Quote Link to comment Share on other sites More sharing options...
fusionff Posted April 21, 2018 Share Posted April 21, 2018 (edited) I had a bunch of failed attempts on programming my 3rd key (MKZ, same procedure). The procedure needs to be done within 30 seconds. I tried a bunch of times and was getting nowhere, then I finally got it to work by using string on the FOBs to speed up the process (I read that trick on another Lincoln forum). It worked on the 1st try with the strings attached. Edited April 22, 2018 by fusionff Quote Link to comment Share on other sites More sharing options...
flagman Posted April 21, 2018 Author Share Posted April 21, 2018 Thanks you, flagman Quote Link to comment Share on other sites More sharing options...
LHB Posted April 21, 2018 Share Posted April 21, 2018 Thanks you, flagman Did this work for you flagman? If it did, did you use the threads or just move faster? Quote Link to comment Share on other sites More sharing options...
flagman Posted April 22, 2018 Author Share Posted April 22, 2018 I had a guy locally offer to do it for 75 bucks so before I got back to the forum thread, he actually had already done it for me I did it within 30 seconds a couple the and didn't get it to work, the dealer where I bought this in Farmington New Mexico told me you couldn't program it yourself, you have to bring it into a dealership or a lovksmith with the computer, for security reasons. I did save a couple hundred bucks over the dealers quote as I bought the key online from carandtruckremotes. Com Quote Link to comment Share on other sites More sharing options...
LHB Posted April 22, 2018 Share Posted April 22, 2018 (edited) Fusionff - Is this the procedure used? (From 2018 Navigator owner manual 1st printing, page86; seems to be removed from 2nd printing)***You must have two previously programmed intelligent access keys inside your vehicle and the new unprogrammed intelligent access key readily accessible. You can purchase replacement keys or remote controls from an authorized dealer.Make sure that the ignition is switched off before beginning this procedure. Make sure that you close all the doors before beginning and that they remain closed throughout the procedure. Carry out all steps within 30 seconds of starting the sequence. Stop and wait for at least one minute before starting again if you carry out any steps out of sequence.Read and understand the entire procedure before you begin.1. Remove the key blade from the transmitter.2. Open the center console storage compartment lid.3. Insert the first programmed key in the backup slot.4. Press the push button ignition switch.5. Wait five seconds and then press the push button ignition switch again.6. Remove the intelligent access key.7. Within 10 seconds, place a second programmed intelligent access key in the backup slot and press the push button ignition switch.8. Wait five seconds and then press the push button ignition switch again.9. Remove the intelligent access key.10. Wait five seconds, then place the unprogrammed intelligent access key in the backup slot and press the push button ignition switch.11. Once complete, the information cluster displays a message confirming the key has been programmed. The direction indicators flash and the horn sounds.Programming is now complete. Check that the remote control functions operate and your vehicle starts with the new intelligent access key.If programming was unsuccessful, wait 10 seconds and repeat steps 1 through 7. If it still does not work, take your vehicle to an authorized dealer.*** Edited April 22, 2018 by LHB Quote Link to comment Share on other sites More sharing options...
fusionff Posted April 23, 2018 Share Posted April 23, 2018 Fusionff - Is this the procedure used? (From 2018 Navigator owner manual 1st printing, page86; seems to be removed from 2nd printing) It's pretty much the same, but not exactly. You must have two previously programmed intelligent access keys inside your vehicle and the new unprogrammed intelligent access keys readily accessible. See an authorized dealer to have the spare key programmed if two previously programmed keys are not available. Make sure that your vehicle is off before beginning this procedure. Make sure that you close all the doors before beginning and that they remain closed throughout the procedure. Perform all steps within 30 seconds of starting the sequence. Stop and wait for at least one minute before starting again if you perform any steps out of sequence. Read and understand the entire procedure before you begin. 1. Remove the rubber covering (A) from the cupholder. Place the first programmed key in the backup slot (B) at the bottom of the cupholder, then press the push button ignition switch. 2. Wait five seconds and then press the push button ignition switch again. 3. Remove the intelligent access key. 4. Within 10 seconds, place a second programmed intelligent access key in the backup slot. Press the push button ignition switch. 5. Wait five seconds and then press the push button ignition switch again. 6. Remove the intelligent access key. 7. Place the unprogrammed intelligent access key in the backup slot and press the push button ignition switch. -Programming is now complete. Verify the remote control functions operate and your vehicle starts with the new intelligent access key. If programming was not successful, wait 10 seconds and repeat Steps 1 through 7. If you are still unsuccessful, take your vehicle to your authorized dealer. Quote Link to comment Share on other sites More sharing options...
boredinbirmingham Posted April 23, 2018 Share Posted April 23, 2018 How much is an extra unprogramed fob anyway? Quote Link to comment Share on other sites More sharing options...
akirby Posted April 23, 2018 Share Posted April 23, 2018 One arm or a small leg. Probably $300 or so. Quote Link to comment Share on other sites More sharing options...
fusionff Posted April 23, 2018 Share Posted April 23, 2018 How much is an extra unprogramed fob anyway? The key & FOB were $85, add $30 to cut the key blade (Which will vary between locksmiths equipped to cut it). So, $115 total. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 24, 2018 Share Posted April 24, 2018 The key & FOB were $85, add $30 to cut the key blade (Which will vary between locksmiths equipped to cut it). So, $115 total. Really? For an Intelligent Access fob?? Quote Link to comment Share on other sites More sharing options...
fusionff Posted April 24, 2018 Share Posted April 24, 2018 Really? For an Intelligent Access fob?? Yes, exact same OEM key sealed in plastic. 3 Admin keys now listed in my menu. Quote Link to comment Share on other sites More sharing options...
LHB Posted April 24, 2018 Share Posted April 24, 2018 (edited) Really? For an Intelligent Access fob??Internet, yea; Lincoln, nay ...https://www.carandtruckremotes.com/2018-lincoln-navigator-smart-remote.html Edited April 24, 2018 by LHB Quote Link to comment Share on other sites More sharing options...
boredinbirmingham Posted April 24, 2018 Share Posted April 24, 2018 The key & FOB were $85, add $30 to cut the key blade (Which will vary between locksmiths equipped to cut it). So, $115 total. Wow thats a lot cheaper than I would have thought. You ordered online? Quote Link to comment Share on other sites More sharing options...
fusionff Posted April 24, 2018 Share Posted April 24, 2018 Wow thats a lot cheaper than I would have thought. You ordered online? Yes, ordered it on Ebay (This seller). There's one listing for as low as $77 now. Some listings do not come with a key, so read carefully before ordering. Quote Link to comment Share on other sites More sharing options...
boredinbirmingham Posted April 24, 2018 Share Posted April 24, 2018 Yes, ordered it on Ebay (This seller). There's one listing for as low as $77 now. Some listings do not come with a key, so read carefully before ordering. Thanks!! Quote Link to comment Share on other sites More sharing options...
LHB Posted March 25, 2019 Share Posted March 25, 2019 Found on eBay (seller remotewholesale) for $79.94 with blank key and free shipping. This fob is actually for the 2018 Navigator as the hatchback control button actually depicts a hatchback rather than a trunk lid like the other fobs I’ve found on line for reasonable prices. The programming instructions from the 2018 Navigator Owners Manual First Printing worked just fine. From 2018 Navigator owner manual 1st printing, page86; seems to be removed from 2nd and 3rd printing) *** You must have two previously programmed intelligent access keys inside your vehicle and the new unprogrammed intelligent access key readily accessible. You can purchase replacement keys or remote controls from an authorized dealer. Make sure that the ignition is switched off before beginning this procedure. Make sure that you close all the doors before beginning and that they remain closed throughout the procedure. Carry out all steps within 30 seconds of starting the sequence. Stop and wait for at least one minute before starting again if you carry out any steps out of sequence. Read and understand the entire procedure before you begin. 1. Remove the key blade from the transmitter. 2. Open the center console storage compartment lid. 3. Insert the first programmed key in the backup slot. 4. Press the push button ignition switch. 5. Wait five seconds and then press the push button ignition switch again. 6. Remove the intelligent access key. 7. Within 10 seconds, place a second programmed intelligent access key in the backup slot and press the push button ignition switch. 8. Wait five seconds and then press the push button ignition switch again. 9. Remove the intelligent access key. 10. Wait five seconds, then place the unprogrammed intelligent access key in the backup slot and press the push button ignition switch. 11. Once complete, the information cluster displays a message confirming the key has been programmed. The direction indicators flash and the horn sounds. Programming is now complete. Check that the remote control functions operate and your vehicle starts with the new intelligent access key. If programming was unsuccessful, wait 10 seconds and repeat steps 1 through 7. If it still does not work, take your vehicle to an authorized dealer. *** Quote Link to comment Share on other sites More sharing options...
Andy L Posted March 25, 2019 Share Posted March 25, 2019 You can program up to 4 fobs. I added 2. Very easy to program. Quote Link to comment Share on other sites More sharing options...
