eBart455987 Posted January 27, 2018 Share Posted January 27, 2018 Ford: Please make the double horn honk after stepping out of car with key in possession and engine running optional. This is a truly annoying feature. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 27, 2018 Share Posted January 27, 2018 It’s easy to avoid. 1 - turn off the car 2 - leave the fob in the vehicle 3 - the simplest - don’t shut the door completely You can also turn it off with Forscan if you’re brave. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 27, 2018 Share Posted January 27, 2018 It’s easy to avoid. 1 - turn off the car 2 - leave the fob in the vehicle 3 - the simplest - don’t shut the door completely You can also turn it off with Forscan if you’re brave. 4 - hold the fob very near the door handle as you shut the door. Quote Link to comment Share on other sites More sharing options...
blwnsmoke Posted February 24, 2018 Share Posted February 24, 2018 (edited) Use Forscan to disable the feature. Done. Us owners have been doing this for several years now. Just a setting change that Forscan to modify. Edited February 24, 2018 by blwnsmoke Quote Link to comment Share on other sites More sharing options...
