fordtech1 Posted July 3, 2019 Share Posted July 3, 2019 1 hour ago, YT90SC said: Our shop has far fewer internal engine issues with the 3.5 of all generations than the 5.0. Lots of knocking, ticking, valve dropping, oil useage issues, out of round holes, and recessed valves with the 5.0. Boost used to be hard on stuff in the old days, but it just isn't as detrimental to long life now. Same experience here. 2011-2014 5.0 seem to be less troublesome than the 15+. I recall 4 ecoboost 3.5 with catastrophic failure. 1 Quote Link to comment Share on other sites More sharing options...
YT90SC Posted July 3, 2019 Share Posted July 3, 2019 I wish we would just stock a PFDI 5.0. Would save a lot of time. Quote Link to comment Share on other sites More sharing options...
CrimsonTideJosh Posted July 13, 2019 Share Posted July 13, 2019 Weight loss. Intercooler swap. Turbo Quote Link to comment Share on other sites More sharing options...
bluedot133 Posted July 31, 2019 Share Posted July 31, 2019 On 12/23/2017 at 6:30 PM, akirby said: Tunes are your best bet. You won’t get much with intakes, exhausts, throttle bodies, etc. - those are fairly well maxed out from the factory. thats good to know Quote Link to comment Share on other sites More sharing options...
theoldwizard Posted August 1, 2019 Share Posted August 1, 2019 If you really want power, get it re-tuned to run E85. Fuel economy is terrible, but it will make a lot of power ! Quote Link to comment Share on other sites More sharing options...
DMG777 Posted August 2, 2019 Share Posted August 2, 2019 On 8/1/2019 at 8:49 AM, theoldwizard said: If you really want power, get it re-tuned to run E85. Fuel economy is terrible, but it will make a lot of power ! How much gain can you expect on an E85 tune versus a 93 tune from stock? Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted August 2, 2019 Share Posted August 2, 2019 3 hours ago, DMG777 said: How much gain can you expect on an E85 tune versus a 93 tune from stock? Hi DMG777. If you look in your Owners Manual, you will see that using E85 fuel, or any fuel containing more than 15% ethanol, is specifically prohibited. The fact that someone will sell you a tune giving you more power will not prevent the damage that fuel will cause to your engine and emissions system components, and resulting warranty issues if you should have problems later. Check your Owners Manual under "Fuel Quality" and "Choosing the Right Fuel". Good luck with whatever you decide to do. 1 Quote Link to comment Share on other sites More sharing options...
DMG777 Posted August 2, 2019 Share Posted August 2, 2019 22 minutes ago, bbf2530 said: Hi DMG777. If you look in your Owners Manual, you will see that using E85 fuel, or any fuel containing more than 15% ethanol, is specifically prohibited. The fact that someone will sell you a tune giving you more power will not prevent the damage that fuel will cause to your engine and emissions system components, and resulting warranty issues if you should have problems later. Check your Owners Manual under "Fuel Quality" and "Choosing the Right Fuel". Good luck with whatever you decide to do. I figured, I planned to get a mild tune with the Livernois T440 package 1 Quote Link to comment Share on other sites More sharing options...
