New Ford 7.0 L....?
The GAA was an interesting engine. It came from an unsuccessful V-12 aircraft engine Ford was working on during WWII that design-wise borrowed a bit from the Rolls-Royce Merlin. Worked very well in tanks, better than air-cooled radials and that 30 cylinder monstrosity Chrysler came up with. The GAA's only fault was that is was a gasoline engine, which made the Sherman somewhat vulnerable. The United States Marine Corps preferred diesel engined tanks, and their Sherman's used twin 6-71 Detroit Diesels. Not quite as powerful as the GAA, but very reliable and safer for the crews.
Actually the engine wasn't the issue with the Sherman and it catching on fire...it was the ammunition carried on it. They solved this problem by putting in a glycerine/water mix blister over/around the ammo, so if it was hit, the glycerine/water would smother the fire from the ammo. The different engines that the Sherman used was due to several factors, but the Marines used M4A3 Shermans late in the war and the only reason they got M4A2 (diesel powered Sherman) was it was easier to get from the supply system early the in war. The Army used the A2 power plant in its Tank Destroyer units, in the M10...but the M10A1 used a gas powered engine. That must have been a logistics nightmare to deal with.
The GAA was used in the Pershing, which it was underpowered for because it weighed more then a Sherman and the GAA was replaced by a Continental V12 in the tanks that succeeded the Pershing and Sherman, which started off gas powered then was converted into a diesel engine because the post-war Tanks used by the US Army and Marines where lucky to go 100 miles on a single tank of gas, when the current standard is more like 200-300 miles.
So what you are saying is, it will not ever be a pushrod design....
  • Like 4
It was all aluminum, 500hp and 1100 cubic inches. It was considered the best American tank engine of all during WWII.
Unfortunately there were a lot of Shermans that burnt up because they were using gas, but that had nothing to do with the quality of the Ford engine. They built to the spec sheet.
Edit:
I stand corrected, as mentioned above, it did have more to do with the protection of the ammunition than the fact it used gasoline verses diesel.
Edited by tbone
hahahah just interjecting some knowlege.
The funny thing is the Conti Diesel engine is still being used today. When I was in the Army 20+ years ago, the recovery vehicle we used had this engine in it...and it was "SLOOOOW" if the M88 could go over 25 MPH, that basically meant the engine was at the end of its life and needed to be replaced.
Interesting, I can see where the Navy would have a better supply of diesel fuel than the Army at the time. I was told most if not all M26's had there GAA's replaced with Continental V-12's after the war.
Edit:
Hmnn-no argument on ammo but seems like I did read that "gasoline in American tanks made them more susceptible to loss vs. Gemans ( Tigers?)which I guess were diesel???
Nope they where petrol powered too
Maybach HL230
https://en.wikipedia.org/wiki/Maybach_HL230
Fire issues with the Sherman
http://knowledgeglue.com/dispelling-myths-surrounding-m4-sherman/
I guess we are done speculating about an engine that will show up sometime around 2020, will likely only be available in class 4 and heavier trucks, might be available in the Mustang, and could be a pushrod/OHV configuration.
Where is the thread on George Hamilton?
Going back to the 6.2L's alleged unsuitability for medium duty truck service (apologies to theoldwizard, I have no reason to doubt him) due to cooling system limitations: I came across something recently that may tend to support that notion (if true): According to a high performance engine builder that supposedly does a lot of 6.2L's for the Raptor crowd, the 6.2L block has siamesed cylinder walls (no coolant passages between the cylinders) and the water jackets only extend about halfway down the cylinder from the deck. Does not sound like the block holds much water. If true, that may indeed explain why the 6.2L is limited to the F-350.
Anyone out there with 6.2L experience that could verify those claims? I have yet to hear of any cooling system problems with the 6.2L in any of it's current applications.
Edited by 7Mary3
Later efficiency and emissions strategies in automotive engines is to run the cylinder barrels hotter and the heads cooler,
I wonder if something like that was baked into the bosses design early on and perhaps acts against it in heavier
truck applications where the engine has extended periods of slogging against heavier loads...
I wasn't aware of the partial siamese sections on the cylinder barrels, the older 400 chev had siamesed bores
and needed additional steam holes in the block to relieve those hot areas where the barrels come together....
I haven't used Calculus since college, why should I go back to it now?
But, even though it's been almost 20 years, I still remember how.
I didn't know how to do it when I was actually in Calculus class so I definitely don't know how to do it today.
That's the one college course I just never understood. My first teacher at our local community college was horrible so I never really learned the basics. I managed to get a C in both courses. Then I got a 105 average in Linear Algebra which was really just matrix multiplication. Why that course came after the Calculus courses is still a mystery - easiest course I ever took.
