a1chem1st Posted January 19, 2014 Share Posted January 19, 2014 I have a 2014 fusion se with the standard audio package (just door speakers none in the rear deck or trunk). I want to install subs but I dont want to change out the deck due to the integration. Am I going to have to figure out how to run a LOC from the back door speakers or is there a lead in the wiring harness for the factory sub option somewhere? Quote Link to comment Share on other sites More sharing options...
a1chem1st Posted January 27, 2014 Author Share Posted January 27, 2014 so glad this forum actually replies to peoples posts thanks so much......... Quote Link to comment Share on other sites More sharing options...
akirby Posted January 27, 2014 Share Posted January 27, 2014 If nobody replies than that means nobody knows the answer. Have you tried www.fordfusionforum.com ? Quote Link to comment Share on other sites More sharing options...
ReadySetSmoke Posted January 27, 2014 Share Posted January 27, 2014 (edited) so glad this forum actually replies to peoples posts thanks so much......... I could reply, but I don't have my car yet, and it's a Titanium, soooo...... But rather than starting a new topic, you may find the help you are looking for here http://www.blueovalforums.com/forums/index.php?/topic/52931-2013-fusion-sub-install/ Edited January 27, 2014 by ReadySetSmoke Quote Link to comment Share on other sites More sharing options...
rukollya Posted April 20, 2014 Share Posted April 20, 2014 I will be posting all the info to wire an amp and sub for the 13-14 fusions very shortly. Within the next few days since I just got around to doing my 13 2.0 Quote Link to comment Share on other sites More sharing options...
brettmcd Posted April 18, 2016 Share Posted April 18, 2016 Have you found out any info on this or done it? If not I have and could share what was done. Quote Link to comment Share on other sites More sharing options...
Scottohar Posted April 25, 2016 Share Posted April 25, 2016 It's very easy - LOC 20.00 Walmart http://www.walmart.com/ip/Scosche-Line-Out-Converter-with-Bass-Control/31954500 How to remove door panels http://www.paulstravelpictures.com/2013-2016-Ford-Fusion-Interior-Door-Panel-Removal-Guide/ Get a soldering gun http://www.walmart.com/ip/25w-Solder-Iron-Kit-L25K/42619693 Tap into the positive and negative wiring on left and right rear doors fish speaker wires through main grommet and run wires down base sidings " they snap off" I'll post pictures on how to run power down to amp - Let me know if you need anymore info. I spent two weekends taking my fusion a part to see what I can and can't do. I'm running 10watts 4 12" subs and all speakers inside are completely swapped out " using Myford Touch head unit still :/ Quote Link to comment Share on other sites More sharing options...
Scottohar Posted April 25, 2016 Share Posted April 25, 2016 (edited) It's very easy - LOC 20.00 Walmart http://www.walmart.com/ip/Scosche-Line-Out-Converter-with-Bass-Control/31954500 How to remove door panels http://www.paulstravelpictures.com/2013-2016-Ford-Fusion-Interior-Door-Panel-Removal-Guide/ Get a soldering gun http://www.walmart.com/ip/25w-Solder-Iron-Kit-L25K/42619693 Tap into the positive and negative wiring on left and right rear doors fish speaker wires through main grommet and run wires down base sidings " they snap off" I'll post pictures on how to run power down to amp - Let me know if you need anymore info. I spent two weekends taking my fusion a part to see what I can and can't do. I'm running 10k watts 4 12" subs and all speakers inside are completely swapped out " using Myford Touch head unit still :/ Edited April 26, 2016 by Scottohar Quote Link to comment Share on other sites More sharing options...
ecordes08 Posted April 26, 2016 Share Posted April 26, 2016 Are the speaker wires that run to the rear door speaker twisted together before going to positive and negative from the main harness? I have the drivers side colors which are the white and green and the brown and yellow but wasn't sure didn't want to splice into any wires til I was sure Quote Link to comment Share on other sites More sharing options...
saint67 Posted June 9, 2016 Share Posted June 9, 2016 (edited) I am in the process of upgrading my 2014 titanium. I am using an LOC from the output of the factory Sony amp, I have bypassed all of the other factory speaker wiring and ran 14ga to each door. in the process I have taken quite a few pictures of locations and wire colors if anyone is interested. HiVi d620 separates front and rear Dayton 10" subs custom fiberglass enclosures NVX 800.4 (F/R amp) NVX 1200.1 (sub amp) Audio Control LCi8 (LOC) Biamp Nexia SP (DSP) I have currently run the two 4GA power wires, (battery must be removed to access the grommet) and all speaker cabling, (also painful as the doors have plug in connectors for wiring). working on the boxes for the subs, next is the amp rack. If anyone needs info this is an ongoing project to be completed this month June 2016. if anyone needs pictures of wiring, locations, sizes of speakers, Etc. hit me up. glad to share the info as there are a lot of questions about the factory systems, with not many answers online. System is almost fully installed. second woofer box tonight. fairly easy car to work on, running wires into the doors sucked as Ford used connection blocks instead of running the wires direct. msheahan7@verizon.net Edited June 29, 2016 by saint67 Quote Link to comment Share on other sites More sharing options...
