robertlane Posted May 26, 2006 Share Posted May 26, 2006 Click here for this article Quote Link to comment Share on other sites More sharing options...
plev72 Posted May 26, 2006 Share Posted May 26, 2006 Click here for this article If I read that properly it gets you ~230hp and ~230lb/ft torque @ 34 mpg in mixed driving??? Quote Link to comment Share on other sites More sharing options...
NickF1011 Posted May 26, 2006 Share Posted May 26, 2006 If I read that properly it gets you ~230hp and ~230lb/ft torque @ 34 mpg in mixed driving??? Good economy, but those power numbers don't seem very impressive if they are going to be putting this engine in cars the size of the S80. Where's the turbo version? :happy feet: Quote Link to comment Share on other sites More sharing options...
NLPRacing Posted May 31, 2006 Share Posted May 31, 2006 Good economy, but those power numbers don't seem very impressive if they are going to be putting this engine in cars the size of the S80. Where's the turbo version? :happy feet: SI6 specifications: Engine type: 6-cylinder in-line engine, petrol, normally aspirated Engine location, drive: Transverse, front-wheel drive Cylinder displacement: 3,192 cc Cylinder bore x stroke: 84 mm x 96 mm Engine block, material: Aluminium Cylinder head, material: Aluminium Number of valves per cylinder: 4 Number of camshafts: 2 Maximum power output: 175 kW (238 PS) at 6,300 rpm Maximum torque: 320 Nm at 3,500 rpm Fuel injection: Port Fuel Injection (PFI) Fuel consumption (preliminary): 28.5mpg (mixed driving cycle) Emissions levels: ULEV II, Euro 5 Weight: 180 kg 230HP from 3.2L isn't too bad for a naturally aspirated, non hi-po engine. To me, that shows that it should have some real potential. This would make a great base engine in the Five Hundred, Montego, Freestyle as well as the upcoming "People Movers" and maybe even the Mustang. I wonder what the displacement potential is? Imagine one of these engines punched out and turbocharged in a a shortened (& lightened) 2 seat Mustang or RX-8 chassis. That would be a fun car to drive! Quote Link to comment Share on other sites More sharing options...
swenson88 Posted May 31, 2006 Share Posted May 31, 2006 230HP from 3.2L isn't too bad for a naturally aspirated, non hi-po engine. To me, that shows that it should have some real potential. This would make a great base engine in the Five Hundred, Montego, Freestyle as well as the upcoming "People Movers" and maybe even the Mustang. I wonder what the displacement potential is? Imagine one of these engines punched out and turbocharged in a a shortened (& lightened) 2 seat Mustang or RX-8 chassis. That would be a fun car to drive! It's not bad power output, but it does seem to be behind most of the competition. Acura has a 3.2 getting 270hp, and all the other makes have the 3.5's getting at least 250hp. If it does get 34mpg highway then that's definitely something to cheer about, but the power numbers will lose on paper to the competition. Quote Link to comment Share on other sites More sharing options...
