myfamilyarelifers Posted October 23, 2009 Share Posted October 23, 2009 Order placed September 30, 2009 I checked out the Ford Fleet VIN results but don't really understand it...can anyone tell me if this means the build is complete? I was told the production sequence number means that the vehicle has been built...can anyone confirm? VIN: 2FMDK4KC3ABA63714 World Manufacturer Identifier - 1st, 2nd, 3rd Positions VIN Code: 2FM Assembly Country: Canada Make: Ford Body Style: Sport Utility Vehicle Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position VIN Code: D Brake System: Standard GVWR Class: Restraint: Du Frnt/Sd/Hd Air Bgs/Rr Hd Ar Bgs/Act Belts GVWR Range: 0 - 6,000 Pounds Line,Series Body Type - 5th, 6th, 7th Positions VIN Code: K4K Vehicle Line: Edge Vehicle Type: Truck Engine Type - 8th Position VIN Code: C Engine: 3.5 L Cylinders: 6 Fuel: Gasoline Engine Manufacturer: FORD Model Year - 10th Position VIN Code: A Model Year: 2010 Assembly Plant - 11th Position VIN Code: B Assembly Plant: OAKVILLE, ONTARIO Production Sequence Number - 12th - 17th VIN Code: A63714 Prod Sequence Number A63714 Additional Information Wheel Axles Wheelbase 222.4 Link to comment Share on other sites More sharing options...
caldriver Posted October 23, 2009 Share Posted October 23, 2009 Order placed September 30, 2009 I checked out the Ford Fleet VIN results but don't really understand it...can anyone tell me if this means the build is complete? I was told the production sequence number means that the vehicle has been built...can anyone confirm? VIN: 2FMDK4KC3ABA63714 World Manufacturer Identifier - 1st, 2nd, 3rd Positions VIN Code: 2FM Assembly Country: Canada Make: Ford Body Style: Sport Utility Vehicle Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position VIN Code: D Brake System: Standard GVWR Class: Restraint: Du Frnt/Sd/Hd Air Bgs/Rr Hd Ar Bgs/Act Belts GVWR Range: 0 - 6,000 Pounds Line,Series Body Type - 5th, 6th, 7th Positions VIN Code: K4K Vehicle Line: Edge Vehicle Type: Truck Engine Type - 8th Position VIN Code: C Engine: 3.5 L Cylinders: 6 Fuel: Gasoline Engine Manufacturer: FORD Model Year - 10th Position VIN Code: A Model Year: 2010 Assembly Plant - 11th Position VIN Code: B Assembly Plant: OAKVILLE, ONTARIO Production Sequence Number - 12th - 17th VIN Code: A63714 Prod Sequence Number A63714 Additional Information Wheel Axles Wheelbase 222.4 This vehicle was scheduled to be built the 27th of October, but the plant is on a 1 week shutdown, possibly 2, due to transmission shortages. The sequence number is just used to help track the vehicle in plant. It has not been started in the body shop as of today. Link to comment Share on other sites More sharing options...
myfamilyarelifers Posted October 23, 2009 Author Share Posted October 23, 2009 This vehicle was scheduled to be built the 27th of October, but the plant is on a 1 week shutdown, possibly 2, due to transmission shortages. The sequence number is just used to help track the vehicle in plant. It has not been started in the body shop as of today. Thank you so much for the quick reply...I appreciate it. So I am looking at the 3rd week of November at the earliest...Thanks again... This is our 2nd Edge - great vehicle!!! Link to comment Share on other sites More sharing options...
