Custom Search
Welcome to Blue Oval Forums
Sign In  Log in with Facebook
Create Account
Guest Message by DevFuse
Ford issues 2 new safety recalls, expands an existing one
  • Please log in to reply
8 replies to this topic
#1 OFFLINE   akirby
akirby
    fordmantpw's alter ego
  • Moderator
  • 28,712 posts
  • Joined 18-April 06
  • Region:Decline
  • Current Vehicle:2018 F150 Supercab XLT Magnetic Grey 3.5LEB
Posted 13 June 2018 - 08:29 AM
https://media.ford.c...th-america.html
Select 2018 Ford F-150, Expedition and Lincoln Navigator vehicles equipped with a 3.5-liter GTDI V6 engine for high-pressure fuel pumps with misaligned welds
Ford is issuing a safety recall in North America for approximately 7,500 2018 Ford F-150, Expedition and Lincoln Navigator vehicles equipped with a 3.5-liter GTDI V6 engine for high-pressure fuel pumps with misaligned welds.
On the affected vehicles, the high-pressure fuel pump assembly may have inadequate welds between the pump housing and its mounting flange. As a result, the fuel pump welds in these vehicles may be susceptible to high-cycle fatigue fractures that could cause the fuel pump to move relative to its mounting flange, resulting in eventual loss of the sealing integrity of the cam cover or the fuel lines and an oil or fuel leak, increasing the risk of fire.
Ford is not aware of any fires, accidents or injuries related to this condition.
Select 2018 Ford F-650 and F-750 vehicles with hydraulic brake systems for missing brake hose corrosion protection plating
Ford is issuing a safety recall in North America for approximately 1,500 2018 Ford F-650 and F-750 vehicles with hydraulic brake systems for missing brake hose corrosion protection plating.
On the affected vehicles, some primary and/or secondary brake circuit hose assemblies located between the master cylinder and the hydraulic control unit may not have the specified anti-corrosion plating on the metal ferrules that attach a flexible braided steel hose to metal tubes. Lack of anti-corrosion plating can lead to premature corrosion of the brake hose ferrules. This can subsequently result in brake fluid leakage and reduced brake function, increasing the risk of a crash.
Ford is not aware of any accidents or injuries related to this condition.
Expansion relating to select 2017-18 Ford Edge, 2017-18 Ford Fusion and 2017 Lincoln MKZ vehicles equipped with a 2.0-liter gas engine and 6F35 transmissions to replace torque converters
Ford is including an additional 27 2018 Ford Edge, 2018 Ford Fusion and 2017 Lincoln MKZ vehicles in an existing safety recall for Ford Edge, Fusion and Lincoln MKZ vehicles equipped with a 2.0-liter gas engine and 6F35 transmissions in North America that may have torque converters with inadequately welded studs.
In the affected vehicles, if the improperly welded studs detach, the torque converter will lose coupling to the engine flexplate, which can result in loss of motive power without warning while driving, which may increase the risk of a crash. The power steering, power brakes, electrical function and vehicle restraint systems will still continue to operate, and the transmission park function will not be affected.
Ford is not aware of any accidents or injuries associated with this issue.
2018 F150 Supercab XLT Sport (Magnetic) - 3.5LEB
2016 Lincoln MKX Reserve (Luxe/Cappucino)
#2 ONLINE   fuzzymoomoo
fuzzymoomoo
    Blue Oval Enthusiast
  • Blue Oval Member
  • PipPipPip
  • 7,961 posts
  • Joined 18-February 14
  • Region:Decline
  • Current Vehicle:2008 Focus, 2018 Fusion
Posted 13 June 2018 - 09:28 AM
The 2.0 liter engine for the Fusion recall, thats the EcoBoost right?
Officially a disgruntled Ford Employee
#3 OFFLINE   akirby
akirby
  • Moderator
  • 28,712 posts
  • Region:Decline
Posted 13 June 2018 - 09:44 AM
Yes. The NA 2.0L isn’t available on Fusion.
#4 ONLINE   fuzzymoomoo
fuzzymoomoo
  • Blue Oval Member
  • PipPipPip
  • 7,961 posts
  • Region:Decline
Posted 13 June 2018 - 09:48 AM
Yes. The NA 2.0L isnt available on Fusion.
Thats what I thought. I was too cheap to spring for the 1.5 so I got the NA engine. Couldnt remember if it was the 2.0 or 2.5
Edited by fuzzymoomoo, 13 June 2018 - 09:48 AM.
#5 OFFLINE   jcartwright99
jcartwright99
    New BON Member
  • Blue Oval Member
  • Pip
  • 468 posts
  • Joined 29-November 10
  • Region:U.S. Great Lakes
  • Current Vehicle:2017 Ford Fusion Titanium AWD
Posted 13 June 2018 - 09:57 AM
Interesting. I just took mine in yesterday for the steering wheel recall and to fix my non closing sunglass holder in the console. Looks like I may need to check if I am effected by this new one.
2017 Ford Fusion
2017 Lincoln MKZ
2014 Ford Escape
2012 Ford Edge
2001 Lincoln LS
1990 Oldsmobile 88
1993 Honda Civic Si
#6 OFFLINE   akirby
akirby
  • Moderator
  • 28,712 posts
  • Region:Decline
2.5
#7 OFFLINE   jasonj80
jasonj80
    Junior Member
  • Blue Oval Member
  • PipPipPip
  • 2,843 posts
  • Joined 12-December 04
Posted 13 June 2018 - 10:01 AM
The Hybrid is a 2.0L NA engine; So you can get one in a Fusion.
#8 ONLINE   fuzzymoomoo
fuzzymoomoo
  • Blue Oval Member
  • PipPipPip
  • 7,961 posts
  • Region:Decline
Posted 13 June 2018 - 10:04 AM
I thought about getting a hybrid actually but decided against it. Second kid on the way I would rather have the full size trunk to be able to fit the double stroller we just got.
#9 OFFLINE   akirby
akirby
  • Moderator
  • 28,712 posts
  • Region:Decline
Posted 13 June 2018 - 10:45 AM
Doh!  Forgot about the hybrid.
Custom Search
