LHB Posted May 14, 2018 Share Posted May 14, 2018 (edited) A(yellow)-Headlight; Low BeamB(white)-Headlight; High BeamC(green)-5LED light bar; function/name/how to turn on ???D(black)-LED double chain runs side of headlights, under headlights along top and bottom of 5LED bar; seem to be welcome and running lights???E(blue)-Directional signals; also flash on vehicle entryF(red)-Fog lights but also on at times other than being turned on with Fog Light Switch-ALSO- I have not been able to define the Parking Lights; turning the Rotating light switch onto or off of the Parking Light position seems to make no difference. Edited May 15, 2018 by LHB Quote Link to comment Share on other sites More sharing options...
Seijirou Posted May 17, 2018 Share Posted May 17, 2018 the "C" lights. Speed-sensitive jewel-like adaptive LED headlamps help direct your attention to where it’s needed on the road ahead. These headlamps cast a wider beam at slower speeds and more focused, longer beams at faster speeds. These come on with the dial in auto while driving at lower speeds. the "D" lights are your daytime running lights and also (I think) your marker lights because unlike a lot of other manufacturers they do not turn off with your blinker. Quote Link to comment Share on other sites More sharing options...
