Custom Search
Welcome to Blue Oval Forums
Sign In  Log in with Facebook
Create Account
Guest Message by DevFuse
Convert 12v acc sockets to ignition on only
  • Please log in to reply
2 replies to this topic
#1 OFFLINE   Billsrey
Billsrey
    New BON Member
  • Blue Oval Member
  • Pip
  • 6 posts
  • Joined 17-January 18
  • Region:U.S. Southern Atlantic
  • Current Vehicle:2017 Ford Transit connect Titanium
Posted 17 January 2018 - 05:14 PM
I have a dash cam I have to plug in every time I drive because the acc sockets are hot all the time. Is there a way to wire the socket on the console so it works with ignition only?
#2 OFFLINE   YT90SC
YT90SC
  • Blue Oval Member
  • PipPip
  • 795 posts
  • Joined 28-July 04
Posted 17 January 2018 - 07:27 PM
Add a relay. Using a standard square Bosch type, cut the power wire to the power point. Connect the cut ends to pins 30 and 87. Connect pin 85 to ground the power point ground. Run a wire from a switched power source, starting at the source with a 3 amp fuse in a holder to pin 86. This setup will keep the load rating of the power point, and the 3 amp fuse will more than feed the relay and provide 'thermal event' protection.
  • fordtech1 likes this
Dad always said,"Knowledge is limited but stupidity knows no bounds."
#3 OFFLINE   Enigma-2
Enigma-2
    New BON Member
  • Blue Oval Member
  • Pip
  • 3 posts
  • Joined 26-May 16
  • Region:U.S. Great Lakes
  • Current Vehicle:2009 Lincoln MKX
Posted 02 June 2018 - 11:45 AM
I realize that this is an old thread but just ran across it and thought I'd add to the discussion.
There is another way of wiring the camera so that it comes on with the ignition and turns off when the ignition is off. Plug the camera into a wiring harness that's connected to the mirror. That's only a few minutes, took me less than 5 to plug in the harness and add a couple of wire ties for strain relief. Works ok, and no wires dangling down to get in the way.
Here's what I use to power my radar detector:
https://www.amazon.c...i_aJSeBb13APNAM
You would choose a harness for your particular mirtor and camera connection.
Custom Search
