2017 ford xl f-350 no powerseat can you plug and play new power seat
winterfrost
Are you meaning for drivers seat? I havent had any experience with a 2017 yet. But in the past I have added power seats. Depending on equipment level, there can be a connector under the seat. If there is then chances are it can be plug and play. Otherwise you will just have to run power and ground with a 30amp circuit breaker. Look under the seat and see if the connector has more wires than is used. There will be two wires going to seat belt buckle.
