Custom Search
Welcome to Blue Oval Forums
Sign In  Log in with Facebook
Create Account
Guest Message by DevFuse
P0456 code on a '12 Edge
Best Answer fordtech1 , 22 December 2017 - 04:54 PM
I bet a beer the purge valve is leaking. Cheapest, easiest way to check it is remove it from the intake and see if you can blow through it. Its a normally closed valve. If you can blow through it, its bad. Go to the full post
  • Please log in to reply
6 replies to this topic
#1 OFFLINE   UNYboater
UNYboater
    New BON Member
  • Blue Oval Member
  • Pip
  • 13 posts
  • Joined 06-March 16
  • Region:U.S. Northeast
  • Current Vehicle:2012 Ford Edge
Posted 22 December 2017 - 02:39 PM
I've gotten this code before on our Edge (Cap-free fuel filler) & some posts seemed to indicate the filler as the likely cause.  I went through the cleaning process, using the fill-tube that's in the spare tire area.  The code went away but returned again after a few months.  This time, the cleaning process didn't help.  I'm thinking it may also be the vacuum purge valve.
Thoughts?  Method to test (short of $6000 worth of testing equipment)?
Thanks as always!
2012 Edge Limited
2007 Coachmen RV (F-450 chassis v10)
2007 Jeep Wrangler
2001 Porsche Boxster S
2006 Harley FLHTCUSE2
#2 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Joined 31-December 06
  • Region:Decline
  • Current Vehicle:2012 Ford Fusion SEL, 2007 Volvo C70, 2006 Mercury Mariner Hybrid, 2005 Ford Focus
Posted 22 December 2017 - 04:54 PM   Best Answer
  • UNYboater likes this
#3 OFFLINE   UNYboater
UNYboater
    New BON Member
  • Blue Oval Member
  • Pip
  • 13 posts
Posted 22 December 2017 - 06:01 PM
On that chance, I picked up a valve on my way home tonight.  Any words of wisdom of removing the old one?
I have gathered that it's on the back of the engine, near the firewall...I'll take any advice available!
2012 Edge Limited
2007 Jeep Wrangler
#4 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 22 December 2017 - 06:11 PM
Really pretty simple. Remove the 2 8mm bolts. Wiggle it and lift out of the intake. The hose is a quick connect so pull the tab back with your thumb and pull the hose off. The hose will snap back on with a simple push. 10 min job tops.
  • twintornados likes this
#5 OFFLINE   UNYboater
UNYboater
    New BON Member
  • Blue Oval Member
  • Pip
  • 13 posts
Posted 23 December 2017 - 11:23 PM
That was the easiest valve replacement I've ever done!  You were right!
I didn't expect it to be visible without removing anything else or having to reach down behind where human arms aren't supposed to go.  It was done in 5 minutes!  Now to see if the code goes away.
The old one *seemed* to allow a little air pressure to escape but it wasn't dramatic.  We'll see tomorrow!
Thanks!
2012 Edge Limited
2007 Jeep Wrangler
#6 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 23 December 2017 - 11:54 PM
Thanks!
Yeah super easy and a common problem. I bet you fixed it. Either way you ruled out a super common problem. So at a minimum you know Its not the valve.
#7 OFFLINE   UNYboater
UNYboater
    New BON Member
  • Blue Oval Member
  • Pip
  • 13 posts
Posted 26 December 2017 - 11:28 AM
CEL went off on its own & all looks well!  Thanks again.
  • NLPRacing and twintornados like this
2012 Edge Limited
2007 Jeep Wrangler
Custom Search
