Custom Search
Welcome to Blue Oval Forums
Sign In  Log in with Facebook
Create Account
Guest Message by DevFuse
No heat on drivers side
heater core
  • Please log in to reply
15 replies to this topic
#1 OFFLINE   buck121
buck121
    New BON Member
  • Blue Oval Member
  • Pip
  • 8 posts
  • Joined 03-December 17
  • Region:U.S. Great Lakes
  • Current Vehicle:2007 Ford Edge
Posted 03 December 2017 - 08:15 PM
I didn't see this question posted any where else , so I figured I would post it here
I have a 2007 Ford Edge , I don't have dual climate controls , just the single control for both sides. I had the heater core cleaned and flushed out 3 years ago , after having no heat , now I have heat only on the passenger side , I was told by my local Ford dealer  that the Heater core needed to be removed and cleaned out , I could see this if I had no heat on either side , bit with normal heat on passenger side , I don't  see how this is possible ,am I correct on this ?
#2 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,731 posts
  • Joined 31-December 06
  • Region:Decline
  • Current Vehicle:2012 Ford Fusion SEL, 2007 Volvo C70, 2006 Mercury Mariner Hybrid, 2005 Ford Focus
Posted 03 December 2017 - 08:31 PM
Chances are the dealer is correct the core is particularly restricted. If you rev up the engine in park does the heat start working a little better? Not completely uncommon. Was the customer satisfaction program performed a while back?
#3 OFFLINE   buck121
buck121
    New BON Member
  • Blue Oval Member
  • Pip
  • 8 posts
Posted 04 December 2017 - 11:40 AM
Hello ,
Thanks for the quick response
Ok I thought it was odd , but like you Said it is partially restricted, it does work a little better when you rev it in park, what is the customer satisfaction program ?
#4 OFFLINE   MKX1960
MKX1960
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 541 posts
  • Joined 12-June 07
  • Region:U.S. Mountain
  • Current Vehicle:2018 Raptor
Posted 04 December 2017 - 05:25 PM
Wasn't there a recall on this? I had an 07 MKX and traded it when I heard about the heater core issue.
#5 OFFLINE   buck121
buck121
    New BON Member
  • Blue Oval Member
  • Pip
  • 8 posts
Posted 04 December 2017 - 06:18 PM
No , I called ford and there was a customer satisfaction notice issued on contaminated cooling system that was to be flushed out ,  but that expired 2009 ,and no recall ,  so I am  taking  it to another mechanic for a second opinion
#6 OFFLINE   buck121
buck121
    New BON Member
  • Blue Oval Member
  • Pip
  • 8 posts
Posted 05 December 2017 - 05:04 PM
I took it to an independent mechanic and his diagnosis is blend door stuck, but you have to replace the entire heater core housing , which is an 8 hour job (1500.00), so I guess I have a warm weather only vehicle ...
#7 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,731 posts
  • Region:Decline
Posted 05 December 2017 - 05:09 PM
Does it go to cold When command it?
#8 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,731 posts
  • Region:Decline
Posted 05 December 2017 - 05:10 PM
Ive never seen that happen on the edge. Unfortunately I disagree with his diagnosis. The entire dash would be cold not just one side If it was a door problem. Is it automatic temperature control or is it manual?
#9 OFFLINE   buck121
buck121
    New BON Member
  • Blue Oval Member
  • Pip
  • 8 posts
Posted 05 December 2017 - 05:46 PM
it is manual control , the mechanic is saying that the blend door on the drivers side  is not opening to let the heat from the heater core in , so you only get the outside air , so I'm not sure what is going on, this mechanic replaced the heater core two years ago , so he claims it is not plugged.
#10 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,731 posts
  • Region:Decline
Posted 05 December 2017 - 08:13 PM
There is only one door so I highly doubt its broke. The passages in the heater core are very small. If the block wasnt flushed like the recall stated it will cause repeat restriction.
#11 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,731 posts
  • Region:Decline
Posted 05 December 2017 - 08:18 PM
http://www.revbase.c...adPdf?id=182324
#12 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,731 posts
  • Region:Decline
Check out that link
#13 OFFLINE   buck121
buck121
    New BON Member
  • Blue Oval Member
  • Pip
  • 8 posts
Posted 06 December 2017 - 10:08 AM
Thanks for the link .... I called Ford and they said CUSTOMER SATISFACTION PROGRAM 09M04-S1 expired in 2009 .... maybe I should write them a letter
#14 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,731 posts
  • Region:Decline
Posted 06 December 2017 - 10:11 AM
I knew it expired but I thought there would be some pretty good information. Its so old I dont think theyll do anything for you unfortunately. It may be worth paying a dealership to do that procedure or a reputable independent. It could save you money in the long run because if you replace it again and if you still have contamination youll be in the same boat.
Edited by fordtech1, 06 December 2017 - 10:12 AM.
#15 OFFLINE   buck121
buck121
    New BON Member
  • Blue Oval Member
  • Pip
  • 8 posts
Posted 06 December 2017 - 10:34 AM
Thanks for the info ,I have to call around to get a quote on this procedure ,like you say its so old that Ford wont pay for it  , its kind of odd that this is showing up now after ten years and 125,000 miles, but it was slow to plug and I had the core replaced two years ago  , but if I have the system flushed out the heater core probably wont get anymore plugged then it is now.if I don't do anything it will eventually plug completely and then no heat at all
#16 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,731 posts
  • Region:Decline
Posted 06 December 2017 - 11:09 AM
Ford wouldnt approve a new core under that program. They fully trusted this procedure. Its a big pain in the butt but t does work
Custom Search
