Woofer-01 Posted November 13, 2017 Share Posted November 13, 2017 I own a 2005 Crown Vic LX Sport and want to replace my 17" 5-spoke Aluminum Wheels. The after wheel market is a bit tricky so I am looking for some info. The Correct Ford Part Number would be helpful.There was a Ford Service Bulletin out several years back about counterfeit wheels. Does anyone have a pdf copy? Specs are different between 200-2001 wheels and the 2003+ wheels While the rims appear the same, there is a difference in the offset and backspacing. Offset Backspacing 2001 - 2002 6mm|1/4" 82.9mm|3-1/4" 2003+ 45mm|1-3/4" 133.4mm|5-1/4" The other rim specifications are the same Bolt Pattern 114.3mm / 4-1/2" x 5 Diameter 17" Width 7" Center Bore 70.5mm / 2-3/4" Any info and advice would be useful. Quote Link to comment Share on other sites More sharing options...
wchain Posted November 23, 2017 Share Posted November 23, 2017 My 11 LX Came from the northern states and the wheels were a little pitted, so I had them refinished locally. Look brand new when they were done. All 03+ Wheels should fit your vic. 98-02 will fit but will stick out and look goofy. Quote Link to comment Share on other sites More sharing options...
