phil1961 Posted October 17, 2017 Share Posted October 17, 2017 Hi Y'all, My 2013 suddenly over the last 2 weeks is haunted with a key fob/receiver issue. Here is the scenario - car does not recognize the fobs. I can attempt auto start and the red light flashes so the fobs are trying to connect with the car. Walk up to the car and cannot unlock. If I use the key blade to enter vehicle and place key fob in cup holder - nothing happens - cannot start car. Then after a while the fobs will work again. Next day same scenario. I have unhooked battery, nothing seems to work. Took it to the dealer, they had it for 4 days and found nothing. I think the receiver is malfunctioning but they won't replace it if they can't reproduce it. Any ideas? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
entropy Posted October 17, 2017 Share Posted October 17, 2017 My 2013 MKZ has had that issue off n on for several years. At one point i had it towed to the dealer with exactly the same results as you.I now have the "open car" code taped inside the rear window so at least i can get into the car (i leave the fob inside car always) I've googled the hell outa the issue, replaced several batteries, started carrying both fobsUsed Uber to get home a couple times. At one point i almost traded it in on a Lexus i was so frustrated. One google came up with other signals maybe interfering with its operation?WTF knows what causes it, Lincoln sure doesn't Good luck to you (and me)Karl GunterSugar Land, Texas Quote Link to comment Share on other sites More sharing options...
coupe3w Posted October 17, 2017 Share Posted October 17, 2017 Got to love technology. Quote Link to comment Share on other sites More sharing options...
murphy62 Posted October 17, 2017 Share Posted October 17, 2017 Don't put your cellphone in the same pocket as the fob. The transmitter in the cellphone will overload the receiver in the fob, because of the close proximity, making the fob "deaf". Quote Link to comment Share on other sites More sharing options...
