silvrsvt Posted September 11, 2017 Share Posted September 11, 2017 When I was going into work today, I noticed a grinding noise coming from the front passenger side wheel when coming to a stop. It doesn't grind when the brake applied...only when the car just comes to a stop (5-10 mph or less) and sometimes it seems like it's grinding just as I let off the brake..like maybe the caliper isn't fully disengaging. Any suggestions? I can't pull the tire till tomorrow to see if there is anything in the caliper itself causing it, but it didn't do it yesterday when I moved the car in for a oil change. Quote Link to comment Share on other sites More sharing options...
fordmantpw Posted September 11, 2017 Share Posted September 11, 2017 Our Flex is horrible at getting rocks stuck between the brake rotor and the shield. Makes a horrible grinding noise at slow speeds. My guess is that is the problem. Fairly easy fix assuming you can see the rock. Quote Link to comment Share on other sites More sharing options...
J-150 Posted September 11, 2017 Share Posted September 11, 2017 Maybe it's the bearing, and you only hear/feel it at that speed. Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted September 12, 2017 Author Share Posted September 12, 2017 I'm a fucking idiot...the bottom engine shield popped off (the back screws came undone) from me doing the oik change and was dragging...thats why I didn't hear it over 15 MPH. Easy fix though Quote Link to comment Share on other sites More sharing options...
tbone Posted September 12, 2017 Share Posted September 12, 2017 It happens to the best of us? Quote Link to comment Share on other sites More sharing options...
