Custom Search
Welcome to Blue Oval Forums
Sign In  Log in with Facebook
Create Account
Guest Message by DevFuse
Running board fails to deploy
  • Please log in to reply
19 replies to this topic
#1 OFFLINE   Bob Rosadini
Bob Rosadini
  • Blue Oval Member
  • PipPipPip
  • 2,677 posts
  • Joined 15-October 99
Posted 10 September 2017 - 07:37 PM
Ok guys, one of the running boards (curb side) on the wife's Explorer (2010 Limited) will not deploy when you open the door.  I switched from "auto" to "always down" to always retracted and back to "auto" with no change.
Any clue?  I got under neath for a look and could see no evidence of any road damage.   also looks like a pretty tight unit to gain access to circuits.
appreciate any thoughts before I take it to dealer.
#2 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Joined 31-December 06
  • Region:Decline
  • Current Vehicle:2012 Ford Fusion SEL, 2007 Volvo C70, 2006 Mercury Mariner Hybrid, 2005 Ford Focus
Posted 10 September 2017 - 08:15 PM
Does it make any noise? Like a hum or buzz for one second or so? Most of the time the hinges are corroded and stuck. Open the door while pushing down on the board. Open and close the door a few times while trying to push it down. Once it starts moving, get some penetrating oil like PB blaster and spray they pivot points. Then open and close the door several times and see it if starts moving on its own
#3 OFFLINE   Bob Rosadini
Bob Rosadini
  • Blue Oval Member
  • PipPipPip
  • 2,677 posts
Posted 10 September 2017 - 08:42 PM
FT-Silent!  And this is a clean well cared for 2010.
#4 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 11 September 2017 - 04:07 PM
Unfortunately I've seen well cared for running boards get frozen up from road debris. However, normally at least a light hum or buzz is heard when door is open. Not a lot of diagnosis can be without seeing it.
#5 OFFLINE   Bob Rosadini
Bob Rosadini
  • Blue Oval Member
  • PipPipPip
  • 2,677 posts
Posted 11 September 2017 - 07:05 PM
Ok- thx for the response in any case. My suspicion is, "no buzz" means there is a wire disconnected from control un it-wherever that is.!
#6 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 11 September 2017 - 07:53 PM
There is one connector next to the motor. Maybe unplug it and check it for water intrusion or poor fit. Another possibility is to disconnect battery for a min to reset the module.
#7 OFFLINE   Bob Rosadini
Bob Rosadini
  • Blue Oval Member
  • PipPipPip
  • 2,677 posts
Posted 12 September 2017 - 07:28 PM
Ok thx will give it a shot.
#8 OFFLINE   Bob Rosadini
Bob Rosadini
  • Blue Oval Member
  • PipPipPip
  • 2,677 posts
Posted 27 October 2017 - 07:42 PM
Well dropped it off at dealer last night. Got a call this afternoon-diagnosis? Short in motor. Solution? "Needs Running board assembly-$2,317.65".
And Hackett wants to cut engineering!  The key wear component in the assembly and you can't get it without buying the whole thing.
I say to service mgr-"you've got to be kidding (well not in those words)- "motor is shot and the entire assembly gets replaced"???  His answer --check out a junk yard!
#9 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 27 October 2017 - 08:11 PM
Check eBay also. I haven't had any experience in this yet. But aftermarket running boards look very similar. I wonder if you can use the parts from them to fix. Or you could buy one assembly and install it. Amp makes one that looks identical to factory
#10 OFFLINE   Bob Rosadini
Bob Rosadini
  • Blue Oval Member
  • PipPipPip
  • 2,677 posts
Posted 27 October 2017 - 08:52 PM
FT-thx I mentioned Junkyard and SM said same thing-try ebay
#11 OFFLINE   twintornados
twintornados
    Ford fan for a long, long time.
  • Blue Oval Member
  • PipPipPip
  • 6,575 posts
  • Joined 16-February 10
  • Region:U.S. Northeast
  • Current Vehicle:2017 Lincoln MKC Reserve
Posted 17 November 2017 - 12:05 PM
Did you have any luck with this Bob?
Does anyone know where the love of god goes, when the waves turn the minutes to hours....Gordon Lightfoot, "Wreck of the Edmund Fitzgerald"
A government big enough to give you everything you want is a government big enough to take from you everything you have. ~ Gerald Ford - August 12, 1974
#12 OFFLINE   Bob Rosadini
Bob Rosadini
  • Blue Oval Member
  • PipPipPip
  • 2,677 posts
Posted 17 November 2017 - 01:09 PM
TT-  No luck.  I went to LKQ and the guy found one in Tenn.  They give you an invoice with location, donor vehicle description including mileage.
I was all set-gave them my CC -185 bucks and day it was due in I get a call and salesman says-"bad news"-number ypu gave guy when you paid for it (I took the "made in Korea" tag off and the kid at counter rpinted it on invoice)   I said .. "well did they ship it" and he says NO.  Strange huh?  This guy was new and I think when someone was checking felt he let it go for too little.  I don't know how LKQ prices stuff but for sure, if only option when yu hve a motor failure is to spend over two grand I would say a salvage motor is worth a lot more than 185-and I would have paid more if he had asked.
There are 3 new ones on Ebay in Canada but wrong nos.
Maybe Hackett will correct this outrage when he cuts engineering and outsourced parts cost.  Korean part?  He might get a better price from a start up in Nigeria :confused:
#13 OFFLINE   fordmantpw
fordmantpw
    akirby's stunt double
  • Blue Oval Member
  • PipPipPip
  • 9,902 posts
  • Joined 30-January 06
  • Region:U.S. Mississippi Valley
  • Current Vehicle:2017 F350 Crew Cab 4x4 PowerStroke Diesel
Posted 17 November 2017 - 01:30 PM
Only if he gives them his bank account number so they can wire him the money his friend left him when he passed away.
Future Vehicles
2020 Ford Explorer/Lincoln Aviator
Current Vehicles
'17 F350 Super Duty Crew Cab, Lariat, 4x4, 6.7L Diesel
'10 Mercury Milan
'09 Ford Flex Limited (wife's)
Past Vehicles
'08 F250 Super Duty Crew Cab, Lariat, 4x4, 6.4L Diesel
'05 Ford F150 XLT SuperCrew 4x4 5.4 - sold @53k, not a single problem
'03 Ford Escape XLT
(wife's) Traded at 75k for '09 Flex
'99 Ford F150 XLT Regular Cab 4x4 5.4 - Sold @136k, then totaled by the new owner on the way to its new home :(
'96 Chevrolet Cavalier (wife's - she brought it into the marriage)
'86 Ford Bronco II XLT 4x4 5 Speed 2.9L - what a dog, and it cracked heads like no tomorrow. 150k+ on 4 engines
#14 OFFLINE   fuzzymoomoo
fuzzymoomoo
    Blue Oval Enthusiast
  • Blue Oval Member
  • PipPipPip
  • 7,351 posts
  • Joined 18-February 14
  • Region:Decline
  • Current Vehicle:2008 Focus, 2015 Focus
Posted 17 November 2017 - 02:22 PM
hey, that guy was my friend! Wtf?
  • fordmantpw likes this
Officially a disgruntled Ford Employee
#15 OFFLINE   Bob Rosadini
Bob Rosadini
  • Blue Oval Member
  • PipPipPip
  • 2,677 posts
Posted 17 November 2017 - 08:44 PM
Sorry guys-can't deal with this right now-just took a message off the answering machine that IRS is about to issue a warrant for my arrest unless I respond at once to their call.    (bet we get two of these a week!)
  • fuzzymoomoo likes this
#16 OFFLINE   fuzzymoomoo
fuzzymoomoo
  • Blue Oval Member
  • PipPipPip
  • 7,351 posts
  • Region:Decline
Posted 17 November 2017 - 10:21 PM
ooh, yeah you might want to get that taken care of. The IRS doesn't mess around!
#17 OFFLINE   fordmantpw
fordmantpw
  • Blue Oval Member
  • PipPipPip
  • 9,902 posts
Posted 17 November 2017 - 10:32 PM
Just send me your SSN and $5k and Ill resolve it for you.
Future Vehicles
Current Vehicles
'10 Mercury Milan
Past Vehicles
'03 Ford Escape XLT
#18 OFFLINE   twintornados
twintornados
  • Blue Oval Member
  • PipPipPip
  • 6,575 posts
Posted 18 November 2017 - 08:52 AM
oooh, I just love those calls.....
#19 OFFLINE   Going_Going_Gone
Going_Going_Gone
    Junior Member
  • Blue Oval Member
  • Pip
  • 213 posts
  • Joined 29-July 03
  • Region:Decline
  • Current Vehicle:F-150 Screw 4X4
Posted 06 January 2018 - 02:03 PM
Ford licensed the right to make their own version of the AMP Research power steps.  They are different in look and the Ford steps have a longer delay before retracting.  The biggest difference between the two is that AMP will sell you a motor, or any other component singly where Ford markets the entire step with motor and idler.  For the kind of money they want for a single step, you could order the top-shelf AMP steps and pay to have them installed, maybe get something for your working side, and still have money left over.  Then, it anything fails, it will be "affordable." Go to electric step website for pricing.
Bob
#20 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 06 January 2018 - 03:21 PM
I figured they were affiliated with amp. Wonder if you could get parts from them and fix it. The main difference I see in the OEM steps is the control. It uses a more complex module and gets inputs from the can network and also can be controlled on and off via cluster. However, I wonder if you could replace with the amp steps and use the oem module to control it.
Custom Search
