silvrsvt Posted July 12, 2017 Share Posted July 12, 2017 So how much engineering input/work did Porsche actually provide for the the Duratec? Quote Link to comment Share on other sites More sharing options...
akirby Posted July 12, 2017 Share Posted July 12, 2017 From what I've heard Porsche did the initial engine design then sold it to Ford who modified it from there. Quote Link to comment Share on other sites More sharing options...
jpd80 Posted July 12, 2017 Share Posted July 12, 2017 (edited) That was the Mondeo / Contour 2.5 & 3.0 V6 not the Cyclone 3.5 V6 From what I gather, Ford shortented the engine to make it more compact Edited July 12, 2017 by jpd80 Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted July 13, 2017 Author Share Posted July 13, 2017 (edited) That was the Mondeo / Contour 2.5 & 3.0 V6 not the Cyclone 3.5 V6 From what I gather, Ford shortented the engine to make it more compact That's why I asked, most of that information is pre-internet, thus not much easily found on it. I know the Cyclone is a different beast...though the 3.0/2.7 are still defined as Ecoboost V6's vs Cyclone, even though the rumor had them mentioned as the Nano engine program? The Duratech was a pretty good V6 outside of it leaking oil on the 3.0L V6 Edited July 13, 2017 by silvrsvt Quote Link to comment Share on other sites More sharing options...
RichardJensen Posted July 13, 2017 Share Posted July 13, 2017 What I've found: http://www.enginebuildermag.com/2005/09/rebuilding-the-ford-3-0l/ While Ford has reaped the Duratec’s benefit, it was not an original design. The primary input for the design of this engine was Porsche, which was already developing the configuration for other purposes. Porsche sold the engineering to Ford and Cosworth, the dominant force behind the cylinder head design. There is actually a 6.0L V-12 Duratec configuration used in the Aston Martin, which is custom built for each vehicle by Cosworth in England. Most sources use a variation of this language, which does not appear to be the correct sequence of events. The definitive source of the Porsche connection looks like an interview w/a Ford engineer published in AutoCar in '94 https://books.google.com/books?id=2UNWAAAAMAAJ&q=porsche+ford+duratec+v6&dq=porsche+ford+duratec+v6&hl=en&sa=X&ved=0ahUKEwjt_IrDyobVAhVB74MKHZxhDRMQ6AEILjAC Unfortunately, you can't get anything more than a snippet view through Google Books. What I've been able to pull from it by creative searching, etc., is that Ford hired Porsche to work on the V6, they did not buy a partially complete V6 design from Porsche. Per this source, the block was cast using a proprietary Cosworth process: https://books.google.com/books?id=IqwiAQAAMAAJ&dq=cosworth+ford+duratec+v6&focus=searchwithinvolume&q=cosworth Quote Link to comment Share on other sites More sharing options...
SoonerLS Posted July 13, 2017 Share Posted July 13, 2017 Per this source, the block was cast using a proprietary Cosworth process: https://books.google.com/books?id=IqwiAQAAMAAJ&dq=cosworth+ford+duratec+v6&focus=searchwithinvolume&q=cosworth That quote appears to be paraphrased from the Lincoln LS brochure, which says that both the AJ V8 and the V6 are "crafted with the patented Cosworth casting process," at least in the '05 brochure I have. Quote Link to comment Share on other sites More sharing options...
