Mustangtiger Posted April 14, 2017 Share Posted April 14, 2017 About to take delivery of a 5.0 Mustang GT, and understand that premium gas is best for best performance, but that the car will run ok on regular gas, yes? Can I alternate tanks of regular versus premium, or if I run one or the other, will it hurt the engine to go back and forth? Maybe I should use the mid range octane as a compromise? Anybody know about this? Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted April 14, 2017 Share Posted April 14, 2017 You can alternate premium vs. regular any time, just make sure your tank is empty when you switch. It won't do any damage switching but you may notice the engine's performance change a little bit with the grade of fuel used. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 14, 2017 Share Posted April 14, 2017 It won't hurt to switch back and forth if you want. Quote Link to comment Share on other sites More sharing options...
Mustangtiger Posted April 14, 2017 Author Share Posted April 14, 2017 What's the issue with needing to make sure the tank is empty? Wouldn't the two grades mix together and simply make a mid rang octane ? 1 Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted April 14, 2017 Share Posted April 14, 2017 What's the issue with needing to make sure the tank is empty? Wouldn't the two grades mix together and simply make a mid rang octane ? I've heard of it messing with the timing and making the engine run rough since the computer has a hard time telling exactly what the octane is when they're blended like that. Quote Link to comment Share on other sites More sharing options...
twintornados Posted April 14, 2017 Share Posted April 14, 2017 (edited) I've heard.... . I've heard that you cannot mix synthetic and regular oil I've heard you must change the oil every 3,000 miles I've heard you cannot cross rotate radial tires I've heard...... Edited April 14, 2017 by twintornados 2 Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted April 14, 2017 Share Posted April 14, 2017 (edited) Well I mean geez, I've never done it myself. I drive a Focus for crisps sake. And when I'm not driving that Focus I'm driving a different, newer Focus. No need for me to even consider that.... Edited April 14, 2017 by fuzzymoomoo 1 Quote Link to comment Share on other sites More sharing options...
OX1 Posted April 15, 2017 Share Posted April 15, 2017 My 14 GT drives the same with regular vs premium and no you don't have to empty tamk when you switch. Only 7 Hp difference on dyno with premium. I do use premium exclusively in hotter months for extra insurance against knock. Quote Link to comment Share on other sites More sharing options...
mettech Posted April 15, 2017 Share Posted April 15, 2017 I don't even mix air in my tires from a different gas station. I only use Shell or BP air. I heard that Shell air is the same air they use in IndyCar. 3 Quote Link to comment Share on other sites More sharing options...
twintornados Posted April 15, 2017 Share Posted April 15, 2017 I don't even mix air in my tires from a different gas station. I only use Shell or BP air. I heard that Shell air is the same air they use in IndyCar. . POTW!!! Quote Link to comment Share on other sites More sharing options...
Mustangtiger Posted April 17, 2017 Author Share Posted April 17, 2017 Thank you all for your input! 1 Quote Link to comment Share on other sites More sharing options...
