MACT Posted March 19, 2017 Share Posted March 19, 2017 Just bought a used 1997 Ranger and was checking it out. Needs some suspension work but the body and engine are in pretty decent shape. Hardly any body rust but the leaf spring links are needing attention along with all new shocks. Only 92K miles on it. Seems like a weekend here or two should be seeing some ride improvements. What are the best leaf spring brackets to purchase? Quote Link to comment Share on other sites More sharing options...
twintornados Posted March 20, 2017 Share Posted March 20, 2017 Just bought a used 1997 Ranger ...... What are the best leaf spring brackets to purchase? . OEM?? Quote Link to comment Share on other sites More sharing options...
J-150 Posted March 20, 2017 Share Posted March 20, 2017 On that vehicle? The cheapest. 1 Quote Link to comment Share on other sites More sharing options...
Sonny Van Sickle Jr Posted March 26, 2017 Share Posted March 26, 2017 We get them from Autozone. Look that frame over closely Had to put a rear frame in a much newer one recently. Quote Link to comment Share on other sites More sharing options...
YT90SC Posted March 30, 2017 Share Posted March 30, 2017 Dorman makes a shackle kit and a hanger kit. Not together. Buy both. Cut the hangers off the frame, cut the shackle bolts off of the springs. Get a ball joint press and push out the old bushings and install the new parts. Quote Link to comment Share on other sites More sharing options...
MACT Posted April 11, 2017 Author Share Posted April 11, 2017 The previous owner only changed the oil!!! Busy replacing all the fluids and the Ranger is now running much better. It has a P1443 code so I am replacing the Purge valve solenoid. I replaced the 20 year old power steering fluid and surprise no leaks yet. Quote Link to comment Share on other sites More sharing options...
MACT Posted April 16, 2017 Author Share Posted April 16, 2017 P1443 code emissions. My first choice on the list of possiblities was the Purge valve and Purge valve sensor as the hoses were rotten also. I replaced the parts and hoses. NO go. I then re-evaluated as I had fuel pressure and chose to replace the Up and down stream O2 sensors. Jack pot. P1443 is now gone. I cleared the codes and drove it with out any other DTC's Now I have to address the AC as it is cycling on and off and is low on Freon. Amazing on how you remove the blanket of issues and find the others laying underneath Quote Link to comment Share on other sites More sharing options...
