Custom Search
Welcome to Blue Oval Forums
Sign In  Log in with Facebook
Create Account
Guest Message by DevFuse
FORDS ALUMINUM BODY SECRET:
  • Please log in to reply
23 replies to this topic
#1 OFFLINE   Craig Morton
Craig Morton
    New BON Member
  • Blue Oval Facebook Member
  • Pip
  • 2 posts
  • Joined 06-March 17
  • Region:U.S. Pacific Coast
  • Current Vehicle:2015 Ford Expedition
Posted 06 March 2017 - 08:36 PM
Our 2015 Ford Expedition with 20,000 miles in California has Aluminum Corrosion on the front hood and rear hatch door. Ford has known about this problem since the year 2000 and has done nothing about it, documented in Technical Service Bulletin TSB 16-0028. Dealerships are aware, but do not disclose the factory defect prior to sale, which is Fraud.
#2 OFFLINE   theoldwizard
theoldwizard
    Retired
  • Blue Oval Member
  • PipPipPip
  • 5,327 posts
  • Joined 06-February 03
  • Current Vehicle:'98 E150
Posted 07 March 2017 - 07:03 AM
First, the TSB was not released until 2016.
Second, a TSB only recommends the best repair procedure.
Third, no one at a dealership is responsible for reading every TSB and and disseminating the information to sales reps.
That TSB applies to 10's of thousands of vehicle.
#3 OFFLINE   twintornados
twintornados
    Ford fan for a long, long time.
  • Blue Oval Member
  • PipPipPip
  • 6,589 posts
  • Joined 16-February 10
  • Region:U.S. Northeast
  • Current Vehicle:2017 Lincoln MKC Reserve
Posted 07 March 2017 - 07:23 AM
It is not really a "secret" if they are publishing a TSB about it.....
  • NLPRacing and akirby like this
Does anyone know where the love of god goes, when the waves turn the minutes to hours....Gordon Lightfoot, "Wreck of the Edmund Fitzgerald"
A government big enough to give you everything you want is a government big enough to take from you everything you have. ~ Gerald Ford - August 12, 1974
#4 OFFLINE   buddysystem
buddysystem
  • Blue Oval Member
  • Pip
  • 246 posts
  • Joined 28-November 99
Posted 07 March 2017 - 10:11 AM
What's different between these corrosion related issues and the new F150?  Are there any early indicators that it may still be a problem or has the new F150 paint process licked the problem?  Too early?
Past Fords:
1997 Explorer XLT (hers)
1994 Mustang Cobra
1989 Probe GT
1988 Festiva (hers)
1986 Mustang GT
Current:
2005 GMC Yukon XL
2013 Honda Pilot (hers)
1955 Willys Wagon
#5 OFFLINE   theoldwizard
theoldwizard
    Retired
  • Blue Oval Member
  • PipPipPip
  • 5,327 posts
Posted 07 March 2017 - 12:54 PM
Well, unless someone from inside the company comes forth and explains the "root cause" of the problem (likely salt water caused corrosion) we will never know.  It is known that very small amounts of cross-contamination (iron dust) on aluminum prior to priming will quickly cause corrosion.  It is also know that the best anti-corrosion primer for aluminum is zinc chromate based (typically a yellow-green color) and NOT the standard steel auto primer.
We do know that Ford is using a new aluminum alloy on the F-series (and likely the Expedition/Navigator) that had NOT been used for auto body panels and is has a new Alco patented treatment (pre-primer). that is applied (IIRC) before the metal is shipped to Ford.
In my own personal "quest", I have spoken to several different professional "bump and paint" folks  Most will gladly take your money and offer no warranty to sand, fill and paint.  Some will recommend replacing the entire panel ($$$) !  One or two go to elaborate lengths of complete removing all trim and components off the door.hatch, removing all paint and primer INCLUDING ON THE INSIDE !! Filling low spots is followed by priming with zinc chromate primer, regular primer, base coat, clear coat and complete re-assembly (also $$$).
Edited by theoldwizard, 08 March 2017 - 07:31 AM.
#6 OFFLINE   akirby
akirby
    fordmantpw's alter ego
  • Moderator
  • 28,031 posts
  • Joined 18-April 06
  • Region:Decline
  • Current Vehicle:2018 F150 Supercab XLT Magnetic Grey 3.5LEB
Posted 07 March 2017 - 12:57 PM
I thought part of the problem is that some parts like Mustang hoods came from suppliers already painted and/or primed.
2013 Fusion Titanium (Ruby Red)
2016 Lincoln MKX Reserve (Luxe/Cappucino)
#7 OFFLINE   theoldwizard
theoldwizard
    Retired
  • Blue Oval Member
  • PipPipPip
  • 5,327 posts
Posted 07 March 2017 - 01:01 PM
Duplicate
Edited by theoldwizard, 07 March 2017 - 01:06 PM.
#8 OFFLINE   theoldwizard
theoldwizard
    Retired
  • Blue Oval Member
  • PipPipPip
  • 5,327 posts
Posted 07 March 2017 - 01:09 PM
I have often wondered about this.  Sounds feasible, as hopefully Ford would be aware of the likelihood of cross contamination if the panels were stamped sides-by-side with steel panels.  I still believe that improper preparation (Were tha panels proper cleaned after assembly ?  Did they use zinc chromate primer ?) is the root cause.
#9 OFFLINE   fuzzymoomoo
fuzzymoomoo
    Blue Oval Enthusiast
  • Blue Oval Member
  • PipPipPip
  • 7,386 posts
  • Joined 18-February 14
  • Region:Decline
  • Current Vehicle:2008 Focus, 2015 Focus
Posted 07 March 2017 - 01:50 PM
that may have used to have been the case with the Mustang at least, but the current Mustang hoods are entirely handled by FRAP from stamping all the way to the end of final assembly.
Officially a disgruntled Ford Employee
#10 ONLINE   silvrsvt
silvrsvt
    Bite my Shiny metal ass!
  • Moderator
  • 18,622 posts
  • Joined 03-October 02
  • Current Vehicle:2017 Escape SE AWD/2013 Taurus SHO
Posted 08 March 2017 - 12:15 PM
I did about 15K worth of front end damage to my Mustang about a year after I got it when I rear ended someone. The hood was replaced and painted by the body shop and I still have bubbling paint under the hood where the creases are.
I don't think this is a factory issue, unless the hood supplier is accidentally contaminating them somehow.
"Hell, there are no rules here-- we're trying to accomplish something."
Thomas A. Edison
Ford Products owned though the years:
1986 Escort GT Race Red
1998 Mustang GT Dark Green Satin
2002 SVT Focus Satin Silver
2006 Mustang GT Tungsten Grey
2010 Escape XLT AWD Sport Blue
2013 Taurus SHO Ruby Red
2017 Escape SE AWD Platinum White
Future Fords:
2021 Bronco
20xx Mustang GT350 or the like
#11 OFFLINE   fuzzymoomoo
fuzzymoomoo
  • Blue Oval Member
  • PipPipPip
  • 7,386 posts
  • Region:Decline
Posted 08 March 2017 - 01:32 PM
MY2015 onwards for sure the supplier is FRAP
#12 OFFLINE   theoldwizard
theoldwizard
    Retired
  • Blue Oval Member
  • PipPipPip
  • 5,327 posts
Posted 09 March 2017 - 07:49 AM
Did the crash parts have zinc chromate primer under the standard primer ?
Proper cleaning of the bare metal, after the part is assembled, and priming are key to preventing aluminum oxidation.
#13 ONLINE   silvrsvt
silvrsvt
  • Moderator
  • 18,622 posts
Posted 09 March 2017 - 11:50 AM
No clue to be honest with you....this was on my 2006
Thomas A. Edison
Future Fords:
2021 Bronco
#14 OFFLINE   blwnsmoke
blwnsmoke
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 931 posts
  • Joined 01-May 07
Posted 11 March 2017 - 09:33 AM
Same thing going on with the Aluminum hood on the Explorers.. paint bubbling and flaking off on the front lip (mostly under the front lip of the hood).  Mine has all the bubbles but hasn't flaked off so I haven't done anything about it.
My understanding was that the aluminum parts were being dipped along with the rest of the vehicle on a universal coating and now the aluminum parts are being dipped by themselves with a better treatment (as mentioned above).
Only time will tell but hoping that this has been resolved as this could be disastrous with Ford on the Fseries if this becomes an issue.
#15 OFFLINE   tbone
tbone
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,607 posts
  • Joined 10-October 05
  • Region:U.S. Great Lakes
  • Current Vehicle:2013 Raptor Supercrew
Posted 13 March 2017 - 09:39 AM
I'm hoping you're right as well. I had bubbles on the rear tailgate of my 07 Expedition. I have seen my fair share of bubbles and peeling on those aluminum parts on other Fords as well. As a matter of fact, I followed an Expedition to work this morning that had a really bad looking tailgate. I would like to think they have this figured out now, considering the major implications it has for the company.
#16 OFFLINE   theoldwizard
theoldwizard
    Retired
  • Blue Oval Member
  • PipPipPip
  • 5,327 posts
Posted 17 March 2017 - 08:23 AM
This is now covered.  From the 2016MY Warranty Guide, page 11.
If aluminum body panels have corrosion or rust damage, and the damage is not the result of abnormal usage, vehicle accident, customer actions and/or extreme environmental conditions, the corrosion or rust damage repairs are covered for 5 years, unlimited miles.
  • fordtech1 likes this
#17 OFFLINE   rjd75
rjd75
    New BON Member
  • Blue Oval Member
  • Pip
  • 6 posts
  • Joined 04-April 08
Posted 01 November 2017 - 09:19 PM
I just booked my 2016 in to get the hood and tailgate repainted, have had it exactly 2 years and noticed it in the summer and getting much worse now.  All 4 of my Expeditions have had this happen and whenever I see a used one drive by I take a look and sure enough today I saw a white one with paint peeling around the tailgate handles and the chrome trim piece.  Not sure how some of you can say it's not a big problem.  I have just accepted it's part of owning one but I hope they have solved this for 2018 because the whole damn thing is aluminum.
#18 OFFLINE   tbone
tbone
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,607 posts
Posted 02 November 2017 - 08:43 AM
I hope you are right about the 2018, as Ive seen a lot of older ones with this problem. If the F150 is indicative, Im optimistic this is resolved.
#19 OFFLINE   akirby
akirby
  • Moderator
  • 28,031 posts
  • Region:Decline
Posted 02 November 2017 - 09:03 AM
It seems to only affect specific vehicles, so it must be a factory problem as opposed to a general Ford problem.   I know Lincoln LS owners with aluminum hoods and fenders that have never had a problem in 17+ years.
#20 OFFLINE   theoldwizard
theoldwizard
    Retired
  • Blue Oval Member
  • PipPipPip
  • 5,327 posts
Posted 02 November 2017 - 09:20 AM
I really think this is the "root cause" !  Quality control at supplier that allowed some type of contamination on the surface prior to them painting it.
I will never be able to find it now, but when the aluminum F150 came out there were several news articles how Ford had worked with Alcoa to develop a special coating that was applied at the aluminum factory.  I think the term the industry uses is "pickling".  This not a primer, which is applied after the body panel is formed, but I am sure that Ford is using the best aluminum primer available,
Edited by theoldwizard, 02 November 2017 - 09:22 AM.
  • 2b2 likes this
Custom Search
