Bsw61per Posted January 23, 2017 Share Posted January 23, 2017 99 F250 6.8 alternator is brand new with brand new batteries, off the truck the alternator produces 14.8 volts, on the truck the alternator produces only 12 volts. Im lost everything that i checked seems to be fine any ideas? Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted January 24, 2017 Share Posted January 24, 2017 Does the battery light illuminate when you turn the key on? Quote Link to comment Share on other sites More sharing options...
Bsw61per Posted January 24, 2017 Author Share Posted January 24, 2017 Yes and stays on Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted January 24, 2017 Share Posted January 24, 2017 Take a test light and check for power on big cable going to the back of the alternator. Unplug regulator and check for power on orange and blue wire. Also, with key on and regulator unplugged the charge light should be off. Plug it back in and light should come on. There should be a white and black wire that goes from regulator 3 wire plug to a single wire plug on alternator. Make sure pins aren't damaged and connect securely. Quote Link to comment Share on other sites More sharing options...
Bsw61per Posted January 25, 2017 Author Share Posted January 25, 2017 Power is present at both plugs, fuseable links are good, no broken wires that I can see. Any more ideas? Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted January 25, 2017 Share Posted January 25, 2017 I have seen where the pins are spread open and don't make contact. Look at those pins closely. I've seen folks take a dvom and probe into the connector and spread the pins. May not be a bad idea to solder in a new regulator connector to rule that out. Quote Link to comment Share on other sites More sharing options...
theoldwizard Posted January 25, 2017 Share Posted January 25, 2017 (edited) Wiring diagram Edited January 25, 2017 by theoldwizard Quote Link to comment Share on other sites More sharing options...
