Schulzie Posted January 16, 2017 Share Posted January 16, 2017 Hello. I've tried searching for this, but no luck. I have a 2013 Fusion SE, and the right directional pad backlight on the steering wheel is going out. The down and left arrow don't light up. Also, the volume buttons look like the lower part is dim. Are these easily fixed? Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted January 16, 2017 Share Posted January 16, 2017 Do they still function properly? If not it could be the clock spring going bad. Quote Link to comment Share on other sites More sharing options...
Schulzie Posted January 16, 2017 Author Share Posted January 16, 2017 The function is 100 %. It's just the blue lighting, In a couple spot . Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted January 16, 2017 Share Posted January 16, 2017 There might be a loose connection somewhere. Unfortunately the only way to check is to remove the airbag which I don't recommend doing on your own. Quote Link to comment Share on other sites More sharing options...
