Why is there no key entry on doors or trunk?
bdegrand
There is a hidden key slot on the driver's door handle. The key is inside of the fob. Described in the Owner's manual.
Yep take key using lite force push to release tab and slide cover off. Then you will expose a key cylinder. Becareful the caps break easy. It takes a little practice.
Before I got my Edge I had a rental which had the missing seam sealer issue. The water must have shorted something in the electrical system, as the fob wouldn't work as I got to the car one night after work. Reading the manual on my phone, in a garage in Chicago, and figuring out how to remove the cover on the handle without breaking it, was no fun.
