Custom Search
Welcome to Blue Oval Forums
Sign In  Log in with Facebook
Create Account
Guest Message by DevFuse
New member looking for help, stumbling problem
  • Please log in to reply
29 replies to this topic
#1 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
  • Joined 04-December 16
  • Region:U.S. Pacific Coast
  • Current Vehicle:2001 Crown Victoria 1994 F150 4X4
Posted 04 December 2016 - 03:23 PM
I have a 2001 Crown Vic Police Interceptor with 198K miles.
I've been dealing with this stumbling problem for at least a year if not more. It seems like this is a common problem. It doesn't throw any codes. I've tried to get real time readings with my code reader and nothing.
It stumbles at the usual 45-50 mphs in 4th with part throttle or at lower speeds in lower gears going up a grade. It happens more with passengers. It doesn't always do it. It even seems to stumble a bit at WOT. It sort of feels like its not getting enough fuel.
It most of the times runs great and gets around 18 mpgs in combined driving.
I've changed the fuel and air filters. I've changed the plugs and cleaned the MAF. I've cleaned all the electrical connections at the coils. The coils are OEM but I don't know how old they really are. They have green Motorcraft logos on them. Visually they look fine as well as the boots.
I'm leaning toward needing coils but I've read it could be the MAF or the TPS. I don't have money to throw at guesses. I really want to solve this once and for all. I used a good quality Matco code reader and was even trying to get soft codes but got nothing. It's frustrating.
Any ideas?
Thanks.
DJ
Edited by Old car fan, 04 December 2016 - 03:24 PM.
#2 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Joined 31-December 06
  • Region:Decline
  • Current Vehicle:2012 Ford Fusion SEL, 2007 Volvo C70, 2006 Mercury Mariner Hybrid, 2005 Ford Focus
Posted 04 December 2016 - 04:01 PM
Your description sounds like a failing coil. You would have no way to find it without some diagnostic equipment. It maybe worth your while to pay for a diagnosis. A power balance test needs to be run and see which cylinder falls out. If your scanner can read mode 6 data. Sometimes it can show which cylinder is higher than others as far as misfire counts.
#3 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 04 December 2016 - 05:24 PM
No as far as I know my scanner doesn't read mode 6 data. My problem is I don't have time to stop by the shop I trust as they aren't open Saturdays and they're usually closed by the time I pass them by on my way home from work during the week.
I'd really like to be sure without a doubt it's the coils before shelling out nearly $300 for a set of new OEM's.
Thanks.
#4 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 04 December 2016 - 05:27 PM
Thanks.
I understand not wanting to throw parts at it. However with out correct diagnosis you will be guessing. Most dealers are open at least half a day on Saturday. They normally charge an hour fee. So probably $95-110 .
#5 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 04 December 2016 - 05:49 PM
I may have to go to a dealer then. I was hoping it would get bad enough to eventually throw a code. I've even tried to prolong a stumbling event to make it throw a code but no luck.
#6 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 04 December 2016 - 06:47 PM
That is a good theory and I have done that. However, sometimes when the coils fail, they create radio frequency interference and freak the pcm out which could mislead you. Especially if the failing coil is closest one to the pcm.
#7 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 04 December 2016 - 07:09 PM
I'd almost be happy with getting any code at this point but a wrong code would really frustrate me. Thanks for that tip.
I miss having a daily driver with points and a carb. There's little to go wrong and repairs are cheap.
Edited by Old car fan, 04 December 2016 - 07:11 PM.
#8 OFFLINE   theoldwizard
theoldwizard
    Retired
  • Blue Oval Member
  • PipPipPip
  • 5,327 posts
  • Joined 06-February 03
  • Current Vehicle:'98 E150
Posted 05 December 2016 - 07:47 AM
Eight coils, especially Motorcraft coils, is a lot of money (>$550 !).
Out of the box theory. It could be an A/C clutch slipping and then re-engaging. Disconnect the A/C clutch and drive for a few days and see if that makes a difference.
#9 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 05 December 2016 - 10:02 AM
I'm sure it's not the A/C clutch as I've had it happened with the A/C off.
I've priced the coils around and a set of OEM's can be bought for less than $300. I would not keep the car any longer if I had to spend $500 as that is the spending limit I have set.
#10 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 06 December 2016 - 11:02 PM
I was told it could be the torque converter causing it. It happens at just over 45 mph and when I lightly tap the brake pedal it unlocks it and the stumble goes away. The only thing though it can sometimes stumble at lower speeds as well. At least a fluid change and flush may be needed.
#11 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 07 December 2016 - 07:10 AM
It can be determined if it's engine or not with a power balance test. Otherwise you are guessing. At low rpm and converter locked the engine is under heavy load. When the converter unlocks it eases the load. Most of the time it's ignition issues from a coil. However could be other things. That's why it's so important for proper test.
#12 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 07 December 2016 - 09:56 AM
Good advice Fordtech but I have a feeling it would take more money and time than I could afford. I haven't changed the transmission fluid since buying the car and I've put nearly 40K miles on it so that may be overdue since who knows when it was changed last.
I'll see how it drives after I get a chance to do a fluid flush and change.
#13 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 25 January 2017 - 03:45 PM
I think I have problem solved. I replaced all the COP's with new Densos and I haven't had an issue since. It runs better than it has for a long time.
It was an easy job taking less than 30 minutes. I think I spent more time opening the boxes and removing the coils from the plastic bags than R&R-ing everything. Most of the clips on the connectors for the injectors are broken. One of them must have gotten knocked loose and lost contact when driving last night. That got me a little worried and made me think at first a brand new coil when bad. It wasn't and the culprit was easy to find.
Now I'm back to enjoying how nice it is to drive this car.
I'm coming up on 200K and this car feels like it easily has less than half than mileage.
#14 OFFLINE   fordtech1
fordtech1
    Blue Oval Member
  • Blue Oval Member
  • PipPip
  • 1,625 posts
  • Region:Decline
Posted 25 January 2017 - 06:41 PM
That's good news. Those clips break so easy. Easiest thing is to take a small zip tie run through the connector and around the injector and pull snug.
  • Sonny Van Sickle Jr likes this
#15 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 25 January 2017 - 10:22 PM
Thanks for the reminder. I had read about the zip tie fix before. Luckily none of the connectors on the COP's broke.
#16 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 03 February 2017 - 03:14 PM
I've been driving it for about week and it's been running great. It has more power now than I can remember it having. I filled up once but half of the driving from that tank was on the old coils. I almost got 17 mpg on that tank. I've never gotten over 19 mpg so I'm hoping to see something better on the next fill up.
  • twintornados likes this
#17 OFFLINE   twintornados
twintornados
    Ford fan for a long, long time.
  • Blue Oval Member
  • PipPipPip
  • 6,582 posts
  • Joined 16-February 10
  • Region:U.S. Northeast
  • Current Vehicle:2017 Lincoln MKC Reserve
Posted 03 February 2017 - 05:17 PM
Good to hear, keep us posted.
Does anyone know where the love of god goes, when the waves turn the minutes to hours....Gordon Lightfoot, "Wreck of the Edmund Fitzgerald"
A government big enough to give you everything you want is a government big enough to take from you everything you have. ~ Gerald Ford - August 12, 1974
#18 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 03 February 2017 - 05:52 PM
You bet. This site is great.
#19 OFFLINE   Old car fan
Old car fan
    New BON Member
  • Blue Oval Member
  • Pip
  • 18 posts
Posted 15 February 2017 - 10:36 PM
Well at my last fill up I got 17.4 mpgs. Not great since I expected a little better. It's more like what I used to get with old coils but it does have more power and it does run better, so I'm not disappointed. I'm wondering if by disconnecting the battery for a while might reset the computer and then running cleared of any soft codes might re-calibrate things?
Edited by Old car fan, 15 February 2017 - 10:37 PM.
#20 OFFLINE   twintornados
twintornados
  • Blue Oval Member
  • PipPipPip
  • 6,582 posts
Posted 16 February 2017 - 07:51 AM
More likely, you are enjoying the renewed power and as such getting a little more liberal with the "go pedal"....give her a couple of tankfuls and ease up on the loud pedal and it should straighten out....glad she is running better.
Edited by twintornados, 16 February 2017 - 07:53 AM.
Custom Search
