rfarmer Posted February 5, 2016 Share Posted February 5, 2016 (edited) I have a F-350 Dually on order with the Max towing option, 6.7 and 4.30 gears. Does anyone have any info on expected MPG empty (not towing)? Thanks in Advance. Edited February 8, 2016 by rfarmer Quote Link to comment Share on other sites More sharing options...
blwnsmoke Posted February 8, 2016 Share Posted February 8, 2016 Depending on speed, 14-16 Quote Link to comment Share on other sites More sharing options...
rfarmer Posted February 8, 2016 Author Share Posted February 8, 2016 Thanks. Quote Link to comment Share on other sites More sharing options...
drifter13 Posted July 25, 2016 Share Posted July 25, 2016 I have a 2015 F350 Dually 6.7 4.30 running with LT245/75R17 14 to 16 right in the range love it surprised at the get and go Quote Link to comment Share on other sites More sharing options...
drifter13 Posted January 2, 2017 Share Posted January 2, 2017 Question about the oil of the 6.7 I've had a couple of oil changes and thought it would keep that fresh oil look for at least a few miles like in my car no towing or hard driving and the oil seems to be black even after the change. Thinking of adding a bypass filter to the system to help eliminate some ware on the engine. Anyone know if that will create warranty issues.Thanks Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted January 6, 2017 Share Posted January 6, 2017 Question about the oil of the 6.7 I've had a couple of oil changes and thought it would keep that fresh oil look for at least a few miles like in my car no towing or hard driving and the oil seems to be black even after the change. Thinking of adding a bypass filter to the system to help eliminate some ware on the engine. Anyone know if that will create warranty issues.Thanks It's been a while since I read it, but IIRC, the Magnuson-Voss Act meant that a warranty couldn't be voided if aftermarket parts were installed unless it was damage attributed to the modification.So, unless it either reduced oil volume/pressure or a line failed and drained the oil, I would think it'd be fine. You could check with the auxiliary filter manufacturer for specifics. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 6, 2017 Share Posted January 6, 2017 If you change the oil system and you have an engine problem attributed to an oil problem they probably won't cover it. But any other type of issue would still be covered. Quote Link to comment Share on other sites More sharing options...
drifter13 Posted November 7, 2018 Share Posted November 7, 2018 Somewhere around 13 to 15 running around empty. Quote Link to comment Share on other sites More sharing options...
drifter13 Posted November 17, 2018 Share Posted November 17, 2018 Thanks on the oil question, from asking around decided to keep it as is. Quote Link to comment Share on other sites More sharing options...
