TysEcoMKT Posted August 2, 2015 Share Posted August 2, 2015 (edited) . Edited August 3, 2015 by TysEcoMKT Quote Link to comment Share on other sites More sharing options...
TysEcoMKT Posted August 2, 2015 Author Share Posted August 2, 2015 (edited) . Edited August 3, 2015 by TysEcoMKT Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted August 2, 2015 Share Posted August 2, 2015 The vehicle is still under the factory 4/50. Everything should be covered. Sounds like the brake rotors need machining. The rear washer could be a pump, line, nozzle issue. However, should be covered as long as it's not damaged from outside source. 2 Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted August 2, 2015 Share Posted August 2, 2015 Why is it not covered? The vehicle is still under 4/50. I don't understand why the brakes are not covered. If the pads still have usable life in them, machining the rotors is covered. Is the washer hose damaged? Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted August 2, 2015 Share Posted August 2, 2015 You can call Lincoln customer service and they will contact dealer and ask why they aren't covering your repairs. Obviously, wear items like pads and other maintenance items are not covered. We machine rotors on Ford vehicles up to 36k under warranty. Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 2, 2015 Share Posted August 2, 2015 (edited) Hello all. I'm new here. I just bought a used 2014 MKT with 34k. The problem I have is when braking, there is a pulsating vibrating noise/feeling. I would take it back to the dealer but they are 300 miles away. Also, my rear window washer fluid is not working. I looked under the hood and I found the line. It's either cut/chewed in half. I can find the other half. Are these covered by warranty? I also purchased the ESP for 100k till 2019. Suck it up and make the drive....they sold you the car, have them make it "right", especially the cut washer fluid line....after all, you drove 300 miles to buy it. Edited August 2, 2015 by twintornados Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 3, 2015 Share Posted August 3, 2015 Suck it up? Ok,...almost 10 hours driving round trip. Then sit all day. Miss a day's pay. Don't think so. Did you teleport to the dealership to buy it?....c'mon guy, you bought a used car and while I agree that the dealership should have taken care of it prior to delivery, they didn't...but to expect another dealership to take it on the chin to fix the issues that the selling dealer should have is a lot of chutzpah on your part....ask the selling dealer to come and get it and fix it....then have them return it to you....did you ask them to do that? 1 Quote Link to comment Share on other sites More sharing options...
TysEcoMKT Posted August 3, 2015 Author Share Posted August 3, 2015 (edited) . Edited August 3, 2015 by TysEcoMKT Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 3, 2015 Share Posted August 3, 2015 Listen bud, I don't need anymore of your rambling.... Too bad...you asked for advice on the forum, I offered my opinions of what you should do.....read your warranty.....brakes are a "wear item" and most warranties won't cover them.....you stated your rear washer fluid line was either cut or chewed....how would a warranty cover what sounds like intentional damage? Someone damaged the line and that would not be covered under a defective part warranty.....now, the original dealer would probably make it right for you, but a servicing dealer 300 miles away? Not likely....Did you ask if your selling dealer would pay for the repairs they should have made prior to you accepting the vehicle for delivery? They should have re-surfaced the rotors during initial inspection when they took the vehicle in....maybe the last person owning it (someone from Lincoln) rode the brakes causing premature wear....either way, you bought a used vehicle and it sounds like the selling dealer did a half-ass job prepping it for re-sale figuring you were 300 miles away and not likely to ever return....you need to put the heat on THAT dealership. Not Lincoln or the servicing dealership. I am sorry you are having a bad experience with your used Lincoln....my experience with my pre-owned certified Lincoln MKX has been nothing but excellent...but then again, the Lincoln dealership I bought it from is less than 15 miles from my home and they treat me exceedingly well. 2 Quote Link to comment Share on other sites More sharing options...
TysEcoMKT Posted August 3, 2015 Author Share Posted August 3, 2015 Post Closed Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 3, 2015 Share Posted August 3, 2015 (edited) Post Closed It ain't closed until a moderator closes it...to wit, on this we agree....your post thread should be closed since you are not willing to hear the sad truth. You got "snookered" and now you want someone else to get you out of it....you got burned by one of the oldest tricks in used car sales, caveat emptor.... Edited August 3, 2015 by twintornados Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 3, 2015 Share Posted August 3, 2015 Post Closed You missed one..... Quote Link to comment Share on other sites More sharing options...
rmc523 Posted August 3, 2015 Share Posted August 3, 2015 I will say the one post I could see today - I know my Flex and others had issues with brake "grinding/creaking" so not sure if that's what he was referring to with that issue. Beyond that, I don't know much about the situation given the posts are deleted. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted August 3, 2015 Share Posted August 3, 2015 . Why bother posting if you just delete it? 2 Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 4, 2015 Share Posted August 4, 2015 . Quote Link to comment Share on other sites More sharing options...
