Seats moving randomly
Hi - I have a 2008 Ford Explorer Limited. Lately when entering with key fob unlock, seat moves back to allow entry, when key is inserted in ignition seat move to driving position that is programmed for that fob. After starting vehicle after a few seconds the seat moves back and interior lights turn on as though I had just pressed the unlock on the key fob. Anyone else out there experienced this? It sometimes does this after I've placed the car in gear as well which is quite startling and unsafe as well.
Thanks for any responses.
There can be an issue with the ignition cylinder. With vehicle running and apply pressure to key and push in towards column and see If your seat doesn't move. There was a SSM about replacing lock cylinders. I've replaced several cylinders. However, a few times I had to replace lock housing.
