CuivreParc Posted September 3, 2014 Share Posted September 3, 2014 Display shows "Key Not Recognized" on my 2013 Escape with IA key FOB. Tried both FOB's, tried placing the FOB on the steering column indentation. Called Ford service, the had me try everything again, had me check the main battery voltage (12.2 V) They sent out a tow truck, and had to drag the Escape out of my garage.(On nylon wedges) Ends up the battery was bad. (The one under the hood) So if you get this message, try jumping the battery before being towed. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 3, 2014 Share Posted September 3, 2014 Why did they have to drag it out on wedges? You can put it in neutral even with a dead battery. The procedure is in the OM. If you don't have a jumper box, get one. They're lifesavers and they're not super expensive. You can jump the vehicle no matter where it's parked. Quote Link to comment Share on other sites More sharing options...
CuivreParc Posted September 3, 2014 Author Share Posted September 3, 2014 You could not shift into neutral, at least not without a jumper box. I will have to look in the owners manual. Thanks Quote Link to comment Share on other sites More sharing options...
akirby Posted September 3, 2014 Share Posted September 3, 2014 There is a manual release next to the shifter. Quote Link to comment Share on other sites More sharing options...
CuivreParc Posted September 3, 2014 Author Share Posted September 3, 2014 In the owners manual page 149-150. You remove the shifter bezel with a flat screwdriver, then you can pull back on a white lever. The tow truck driver probable did not want to take a chance on scratching or breaking the bezel. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 3, 2014 Share Posted September 3, 2014 The tow truck driver probable did not want to take a chance on scratching or breaking the bezel. To be honest that's really up to the owner to perform (and know how to do it or look it up). Every vehicle is different and it's not reasonable for the tow truck driver to know how to do every vehicle (or take the time to figure it out). That's why it's called the owner's manual not the tow truck driver's manual. Quote Link to comment Share on other sites More sharing options...
CuivreParc Posted September 3, 2014 Author Share Posted September 3, 2014 I agree Quote Link to comment Share on other sites More sharing options...
Escapism Posted September 4, 2014 Share Posted September 4, 2014 To be honest that's really up to the owner to perform (and know how to do it or look it up). Every vehicle is different and it's not reasonable for the tow truck driver to know how to do every vehicle (or take the time to figure it out). That's why it's called the owner's manual not the tow truck driver's manual. Not to mention a bezel is alot cheaper than a transmission. I wouldn't want anybody dragging my car. But thats cool that they have those wedges. Quote Link to comment Share on other sites More sharing options...
sasscuba Posted November 26, 2014 Share Posted November 26, 2014 What was the fix? Mine has been in twice going in for a third time Monday Quote Link to comment Share on other sites More sharing options...
bigbobsha Posted November 26, 2014 Share Posted November 26, 2014 Did you have the wiring harness recall done? Quote Link to comment Share on other sites More sharing options...
CuivreParc Posted December 2, 2014 Author Share Posted December 2, 2014 The fix was to replace the battery. (The one under the hood, not the key FOB) I had the wiring harness recall done after the key not recognized problem. Quote Link to comment Share on other sites More sharing options...
