2012 Exp limited EL remote start
stangfvr
I have the factory/dealer installed remote start on my 12 MY exp. After I remote start it and open the door to get in, the vehicle shuts off. Any thoughts on what I am doing wrong? I haven't used this option because I can not keep the vehicle running after I open the door. :(
Waloud, you most likely have a different style of RMST. I am betting that yours is integrated in the key and stangfvr yours has an additional fob for it? IF indeed that is the case, then they are both functioning as designed.
Most people use RMST to heat or cool the cabin before they get in- that is the point, nothing else. Different shutdowns are provisions for different safety reasons. The brake shutdown is so no one can get it out of gear to steal it. The door open and key in ignition shutdowns are so MyKey functionality is not lost.
You still have to put the key in the ignition to drive off, so I am not sure what the issue is? If it is the re-start, that is actually easier on the vehicle than forcing it to cold idle for 15 minutes.
