FusionNewbie Posted May 27, 2013 Share Posted May 27, 2013 (edited) Hey all, For whatever reason, I've started noticing this super obnoxious rattling noise coming from somewhere around the passenger A-Pillar...I can't tell if it's a dash issue, something with the trim, or what - does anyone else experience this? I uploaded a video of the sound while driving - you have to listen carefully and block out the road noise to hear it. (and no, I was not the one recording the video while driving) $5 to anyone who guesses which road I was on. I have to take it into the dealer for it's first oil change soon - so I'll mention to it then at the very least. Will showing this video to them help? Edited May 27, 2013 by FusionNewbie Quote Link to comment Share on other sites More sharing options...
Chris1970 Posted May 27, 2013 Share Posted May 27, 2013 Hey Newbie, tap the little black plastic panels behind the door pull, if it rattles as you do it, that is most likely the cause. I had that happen for 2 months or so and was driving me crazy (had to fix that on all 4 doors). They are just loose and need to be fastened better. Let me know if that is the culprit. Quote Link to comment Share on other sites More sharing options...
jinx8402 Posted May 27, 2013 Share Posted May 27, 2013 And if it is the panel behind the door handle, there is a tsb for it and you can have the dealer fix it when you bring it in for the oil change. Quote Link to comment Share on other sites More sharing options...
Chris1970 Posted May 28, 2013 Share Posted May 28, 2013 Where can you obtain the TSB info jinx? Quote Link to comment Share on other sites More sharing options...
FusionNewbie Posted May 28, 2013 Author Share Posted May 28, 2013 Yeah, I'll definitely check it out tomorrow on my drive to work. I plan to get the oil change, have them check the TSB for the clicking noise, and the TSB for this. If you had a link to this one it would be great. Quote Link to comment Share on other sites More sharing options...
jinx8402 Posted May 28, 2013 Share Posted May 28, 2013 http://www.fordservicecontent.com/pubs/content/~WT/~MUS~LEN/3567/tsb13-05-03.pdf it takes some googling to find the tsb's. If you search this whole string: site:fordservicecontent.com fusion it should bring up all fusion related tsb's. Quote Link to comment Share on other sites More sharing options...
Chris1970 Posted May 28, 2013 Share Posted May 28, 2013 Thanks for the great link info Quote Link to comment Share on other sites More sharing options...
FusionNewbie Posted May 28, 2013 Author Share Posted May 28, 2013 Checked it on the way into work this morning - I heard the rattling a litle bit and pressed on the handle backing and it didn't stop. Any other ideas? Quote Link to comment Share on other sites More sharing options...
bucky919 Posted May 28, 2013 Share Posted May 28, 2013 The metal clips that hold the door panel rattle on mine, haven't had a chance to take in though. Quote Link to comment Share on other sites More sharing options...
gl419 Posted May 28, 2013 Share Posted May 28, 2013 Looks like your driving the GW Parkway around Arlington Cemetary. I lived in Annandale back in the mid 70's and my wife and I used to like to hike Roosevelt Island. Interesting place that was off the the beaten path. Quote Link to comment Share on other sites More sharing options...
Jamers Posted October 23, 2013 Share Posted October 23, 2013 Hey FusionNewbie, I too have a passenger side dash rattle. It is driving me nuts. It started a couple months ago. My Fusion was built in March 2013 it is not related to the TSB mentioned above. I haven't taken it to the Dealer yet but plan to soon. Have you had any luck eliminating the noise on your end? Quote Link to comment Share on other sites More sharing options...
FusionNewbie Posted October 23, 2013 Author Share Posted October 23, 2013 Hey FusionNewbie, I too have a passenger side dash rattle. It is driving me nuts. It started a couple months ago. My Fusion was built in March 2013 it is not related to the TSB mentioned above. I haven't taken it to the Dealer yet but plan to soon. Have you had any luck eliminating the noise on your end? I haven't heard the noise for a while but unfortunately I can't give a reason as to why...when I took it to the dealer I was getting the gas tank replaced, fuel filler replaced, the A-pillar trim replaced, an oil change, and a tire replacement (damn nails) so it kind of fell through the cracks. Quote Link to comment Share on other sites More sharing options...
FusionNewbie Posted October 23, 2013 Author Share Posted October 23, 2013 Looks like your driving the GW Parkway around Arlington Cemetary. I lived in Annandale back in the mid 70's and my wife and I used to like to hike Roosevelt Island. Interesting place that was off the the beaten path. Close . Rock Creek Parkway. Quote Link to comment Share on other sites More sharing options...
Jamers Posted October 23, 2013 Share Posted October 23, 2013 Why did they replace the A pillar trim? Was it the Driver or Passenger side? Maybe the rattle is in the pillar? Quote Link to comment Share on other sites More sharing options...
FusionNewbie Posted October 23, 2013 Author Share Posted October 23, 2013 They replaced the vertical a-pillar trim on the outside of the vehicle because the trim was peeling off. This was not the cause of the rattle as the rattle would exist when the car was at a stop. I also verified the location of the rattle because every time I would push the vent on the INSIDE of the vehicle, the rattle would stop until I let go. Hopefully that made sense... Quote Link to comment Share on other sites More sharing options...
kp296 Posted March 8, 2017 Share Posted March 8, 2017 @FusionNewbie, I know this is an old thread but did you ever figure this out?? I have a 17' Fusion Hybrid and have the exact same noise. Its hard to tell what side its coming from, but I read something about pebbles between the heatshield? It definitely sounds like it could be that and it is driving me insane. Quote Link to comment Share on other sites More sharing options...
20Fusion16 Posted March 9, 2017 Share Posted March 9, 2017 @kp296, This rattle started for me today. Check the weather strip along the back window. There should be a small gap, kinda like a buffer zone. Part of mine compressed and caused the noise. I stretched it out again and the noise went away. Quote Link to comment Share on other sites More sharing options...
