dbmaven Posted November 29, 2012 Share Posted November 29, 2012 Several people have noted that this item has started appearing in ETIS for their VIN on 2013 Fusions. Yesterday there were no Google hits, today this showed up: 5378 - Announcing Field Service Action 12C27 DELIVERY HOLD - Compliance Recall 12C27 - Certain 2013 Model Year Fusion Vehicles - Headlamp Assembly Replacement. REFER TO FMCDEALER.COM FOR DETAILS. Source: http://www.vrep.fordtechservice.dealerconnection.com/vdirs/oasis/oareq.asp?broadcast=ON&from= Anyone have additional information?? "Compliance recall" would seem to suggest something relatively serious..... Since I already have my Fusion I'm wondering what the deal is, since it can't be subject to a delivery hold...... Quote Link to comment Share on other sites More sharing options...
akirby Posted November 29, 2012 Share Posted November 29, 2012 Simple - they need to replace the headlamps. Compliance in this case means compliance to DOT regs for headlamps. Quote Link to comment Share on other sites More sharing options...
dbmaven Posted November 29, 2012 Author Share Posted November 29, 2012 Thanks akirby - I should have been more specific. By the wording I can tell it's a replacement as opposed to some sort of adjustment. Simply wondering if anyone has the details. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 29, 2012 Share Posted November 29, 2012 (edited) The details are that the headlamps are defective and need to be replaced. There really isn't anything more to be said. If you're wondering what's wrong with them - we'll probably never know. From the wording I would guess something in the original part didn't meet DOT specs. Edited November 29, 2012 by akirby Quote Link to comment Share on other sites More sharing options...
Salva Posted November 29, 2012 Share Posted November 29, 2012 The OP on the following thread, elsewhere in these forums, included some wording in quotes that I assume is from the original notice. It gives a bit more detail. http://www.blueovalforums.com/forums/index.php?/topic/51796-2013-fusion-headlamp-recall/ Quote Link to comment Share on other sites More sharing options...
vincep5 Posted November 29, 2012 Share Posted November 29, 2012 Yes, thanks dbmaven and salva for those updates. Looks like the rumors about headlights were true! I'll be visiting my dealer on Monday to fix the fit issue I have about the trunk and hood, fixing the MFT upgrade, and seeing if they heard about this headlight issue. I have a feeling I'll have to set up another appointment for the headlights. Quote Link to comment Share on other sites More sharing options...
Camride Posted November 29, 2012 Share Posted November 29, 2012 It appears this is only a problem on the earlier builds. My guess is a bad batch of headlights. Mine was built 11/17 and it's only showing the 12A04 MFT upgrade. Quote Link to comment Share on other sites More sharing options...
FusionHybrid2013 Posted November 29, 2012 Share Posted November 29, 2012 Is there a way to validate whether my car is included in the recall? Or do I just need to call a dealeship? Quote Link to comment Share on other sites More sharing options...
hermans Posted November 29, 2012 Share Posted November 29, 2012 (edited) It appears this is only a problem on the earlier builds. My guess is a bad batch of headlights. Mine was built 11/17 and it's only showing the 12A04 MFT upgrade. Mine was built on 11/19 and there are no field service messages. It's now riding the rails. Edited November 29, 2012 by hermans 1 Quote Link to comment Share on other sites More sharing options...
Salva Posted November 29, 2012 Share Posted November 29, 2012 Is there a way to validate whether my car is included in the recall? Or do I just need to call a dealeship? You probably should talk to the dealer in any case, but you can also try. 1) Ford etis - google for "ford etis" and go to vehicle / vehicle lookup. Type your VIN and it will tell you a lot of stuff about your vehicle, including (on the left) a list of outsanding field service actions. I personally used this with VINs of cars in a nearby dealer lot and it did get some hits for this recall. 2)I believe Ford has a consumer friendly recall web page. I goggled "ford recall" and got to a page where you could type your VIN and see any pending recalls. I haven't tried it, though. Quote Link to comment Share on other sites More sharing options...
neod192 Posted November 29, 2012 Share Posted November 29, 2012 1) Ford etis - google for "ford etis" and go to vehicle / vehicle lookup. Type your VIN and it will tell you a lot of stuff about your vehicle, including (on the left) a list of outsanding field service actions. I personally used this with VINs of cars in a nearby dealer lot and it did get some hits for this recall. I did this for my local dealer and all Titanium "Dealer Ordered" models show "12A04 - SYNC WITH MYFORD/MYLINCOLN TOUCH - APPLICATION PERFORMANCE UPGRADE" while all "Available in stock" have 12C27 - HEADLAMP ASSEMBLY REPLACEMENT". The hybrid models all say "No Campaign Message(s) found", even the ones that have SE HYB TECH/MY FORD TOUCH PKG on the window sticker. Quote Link to comment Share on other sites More sharing options...
hermans Posted November 29, 2012 Share Posted November 29, 2012 I did this for my local dealer and all Titanium "Dealer Ordered" models show "12A04 - SYNC WITH MYFORD/MYLINCOLN TOUCH - APPLICATION PERFORMANCE UPGRADE" while all "Available in stock" have 12C27 - HEADLAMP ASSEMBLY REPLACEMENT". The hybrid models all say "No Campaign Message(s) found", even the ones that have SE HYB TECH/MY FORD TOUCH PKG on the window sticker. This can be a mystery. My Fusion hybrid was build on the 17th , shows no Field Service Messages and is currently on a railcar headed in my direction on the East coast. Quote Link to comment Share on other sites More sharing options...
neod192 Posted November 29, 2012 Share Posted November 29, 2012 This can be a mystery. My Fusion hybrid was build on the 17th , shows no Field Service Messages and is currently on a railcar headed in my direction on the East coast. Maybe they already replaced the headlights before they loaded it to the railcar. Quote Link to comment Share on other sites More sharing options...
elle Posted November 29, 2012 Share Posted November 29, 2012 And maybe the hybrids were already getting the upgrade when they started rolling out. Interesting to see that apparently there are two issues that were rumored here proving to be correct-- the software upgrade and the headlights. Quote Link to comment Share on other sites More sharing options...
Salva Posted November 29, 2012 Share Posted November 29, 2012 This can be a mystery. My Fusion hybrid was build on the 17th , shows no Field Service Messages and is currently on a railcar headed in my direction on the East coast. On the headlamps issue - somebody in another thread said the actual recall covers vehicles built up to Oct 20th. So yeah, hopefully all being built for a while have fixed headlamps. On MFT - well if they have the version released for updates, I see no reason why they wouldn't load it in newly built units. Be happy, this is what new cars are supposed to look like, coming out of the factory. Nothing to fix :-) Quote Link to comment Share on other sites More sharing options...
hermans Posted November 29, 2012 Share Posted November 29, 2012 Maybe they already replaced the headlights before they loaded it to the railcar. Could be, but there are cars with both issues that were built after mine. Like I say - It's a mystery. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 29, 2012 Share Posted November 29, 2012 This can be a mystery. My Fusion hybrid was build on the 17th , shows no Field Service Messages and is currently on a railcar headed in my direction on the East coast. Not a mystery. New builds have everything fixed already. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 29, 2012 Share Posted November 29, 2012 Could be, but there are cars with both issues that were built after mine. Like I say - It's a mystery. How do you know they were built after yours? You can't go by VIN. It's also possible that yours was fixed first because it's a retail order. Quote Link to comment Share on other sites More sharing options...
Camride Posted November 29, 2012 Share Posted November 29, 2012 Could be, but there are cars with both issues that were built after mine. Like I say - It's a mystery. My car showed no field service until after it was in transit. Quote Link to comment Share on other sites More sharing options...
hermans Posted November 29, 2012 Share Posted November 29, 2012 (edited) How do you know they were built after yours? You can't go by VIN. It's also possible that yours was fixed first because it's a retail order. I looked up VINs in FordEtis. Edited November 29, 2012 by hermans Quote Link to comment Share on other sites More sharing options...
-Strike- Posted November 29, 2012 Share Posted November 29, 2012 Just checked mine out today, 12T08 is gone, and has been replaced by " 12A04 - SYNC WITH MYFORD/MYLINCOLN TOUCH - APPLICATION PERFORMANCE UPGRADE" I'll ask my dealer about this on Saturday, fiddling with the car this morning, everything appeared to work fine, pretty quick, no delays in voice commands or anything. Quote Link to comment Share on other sites More sharing options...
Morcelu Posted November 29, 2012 Share Posted November 29, 2012 Mine changed to 12A04 the other day as well. Still hasn't shipped as of today, though. Quote Link to comment Share on other sites More sharing options...
neod192 Posted November 29, 2012 Share Posted November 29, 2012 Maybe they're just not figuring out which car needs what fixed They might even have them piled up nicely in a way they can get to all of them easily. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 29, 2012 Share Posted November 29, 2012 Maybe they're just not figuring out which car needs what fixed They might even have them piled up nicely in a way they can get to all of them easily. 2 Quote Link to comment Share on other sites More sharing options...
bobdivot Posted November 29, 2012 Share Posted November 29, 2012 When I search ETIS for my car it comes up as a Transit Connect Van? Any ideas? Quote Link to comment Share on other sites More sharing options...
