ruteger Posted September 17, 2012 Share Posted September 17, 2012 Besides the afrorementioned A/C which rarely keeps the same previous setting upon start-up (either turning off or reverting back to 'recirculate'), the instrument panel rheostat doesn't seem to work. I wouldn't mind so much but the brightly lit instrument panel gauges are rather dangerous because, at night, it looks like the headlights are on (don't have the auto-lights). Also, the power windows seem inordinately slow to raise/lower. I guess maybe this is the price to pay for going with a bottom-feeder 'S'. Quote Link to comment Share on other sites More sharing options...
digijay Posted September 17, 2012 Share Posted September 17, 2012 On mine, I found a setting on the info centre which had to do with automatic/ manual lighting. When I turned off Automatic, I was able to adjust the brightness of the gauges/ screens. Quote Link to comment Share on other sites More sharing options...
svtenthusiast Posted September 18, 2012 Share Posted September 18, 2012 (edited) To build on what the poster above stated: When the lighting is set to automatic in the message center, during the day you cannot use the dimmer, at night with the headlamps on you can. When the lighting is set to manual in the message center, during the day you can use the dimmer control. Edited September 18, 2012 by svtenthusiast Quote Link to comment Share on other sites More sharing options...
ruteger Posted September 18, 2012 Author Share Posted September 18, 2012 (edited) As it turns out, it 'was' on manual. No adjustment available, whatsoever. However, when I put it on 'auto', in addition to (apparently) adjusting automatically, the dimming can also be adjusted manually. So, what's the point of the 'manual' setting? It does nothing but lock the lighting to it's highest setting. Edited September 19, 2012 by ruteger Quote Link to comment Share on other sites More sharing options...
pillboy Posted September 19, 2012 Share Posted September 19, 2012 Another example of a simple function turned into a cluster &$#@ by computerizing the procedure. The auto industry consumer would be much better off if they fired half of the electrical engineers. 1 Quote Link to comment Share on other sites More sharing options...
