anthony_b Posted July 28, 2011 Share Posted July 28, 2011 ...bought a new FOMOCO timing belt and water pump. Gonna do it soon. Owner's manual said it should be done at 120,000mi and I just now turned that. Been going over it in the Hayne's Manual a good bit. ...question I got is do these actually really need changed? I've talked to several 2.5 4 cyl Ranger owners that have 150k to 200k on their trucks and when I've inquired about ever having their timing belts changed they said "What timing belt?" ...just don't know "how much" of a hurry I should be in to change it? Wait til the water pump goes first? Quote Link to comment Share on other sites More sharing options...
YT90SC Posted July 28, 2011 Share Posted July 28, 2011 ...bought a new FOMOCO timing belt and water pump. Gonna do it soon. Owner's manual said it should be done at 120,000mi and I just now turned that. Been going over it in the Hayne's Manual a good bit. ...question I got is do these actually really need changed? I've talked to several 2.5 4 cyl Ranger owners that have 150k to 200k on their trucks and when I've inquired about ever having their timing belts changed they said "What timing belt?" ...just don't know "how much" of a hurry I should be in to change it? Wait til the water pump goes first? IF it breaks, it quits running. THese are a 'freewheeling' or NON interfereance engine. IF it breaks it will do no damage. IF it were mine, I would drive it till it breaks and then replace the pump at that time. Quote Link to comment Share on other sites More sharing options...
RangerM Posted July 28, 2011 Share Posted July 28, 2011 ...question I got is do these actually really need changed? I've talked to several 2.5 4 cyl Ranger owners that have 150k to 200k on their trucks and when I've inquired about ever having their timing belts changed they said "What timing belt?" That would've been my response. I'd have thought the Ranger would have a timing chain and a non-interference engine. Replace it when it breaks. Quote Link to comment Share on other sites More sharing options...
anthony_b Posted July 28, 2011 Author Share Posted July 28, 2011 IF it breaks, it quits running. THese are a 'freewheeling' or NON interfereance engine. IF it breaks it will do no damage. IF it were mine, I would drive it till it breaks and then replace the pump at that time. ...I guess I thought this was an "Interference Engine" as the Haynes Manual says on page 2A-5, "...if the timing belts breaks during engine operation, EXTENSIVE damage may occur!!!". Wasn't sure after reading that. Thanks for the response. Quote Link to comment Share on other sites More sharing options...
YT90SC Posted July 29, 2011 Share Posted July 29, 2011 ...I guess I thought this was an "Interference Engine" as the Haynes Manual says on page 2A-5, "...if the timing belts breaks during engine operation, EXTENSIVE damage may occur!!!". Wasn't sure after reading that. Thanks for the response. After the 1.6l fiasco in the early 80's no NAAO Ford built engine with a timing belt is an interference engine. Noteable exclusions are the non ford built engines in the first and second gen SHO's, possibly the Mazda engines in probes and Escort GT's, Villager and possibly the Aussie Capris. IIRC, Festivas and Assfires (kia built) are non interference as well. Quote Link to comment Share on other sites More sharing options...
