RangerM Posted March 6, 2011 Share Posted March 6, 2011 Probably going to have to buy tires for my Ranger in the next year or so. Size 225/70R14. These are getting hard to find. If you do find a store that carries them, they usually only have one model available. It's hard to believe there aren't more vehicles out there that use this size. Quote Link to comment Share on other sites More sharing options...
p38fln Posted March 7, 2011 Share Posted March 7, 2011 (edited) My Ranger uses MUCH different tires - P245/75R16SL Just under $400 for a set of four Firestone Destination LE tires installed. I looked up what the heck "SL" means - agricultural use only. No wonder I couldn't find any in stock anywhere It's just got regular P245/75R16 installed now. Edited March 7, 2011 by p38fln Quote Link to comment Share on other sites More sharing options...
GTwannabe Posted March 7, 2011 Share Posted March 7, 2011 Find a Ranger in a junkyard with larger/better wheels, then put new tires on those and align the truck. Quote Link to comment Share on other sites More sharing options...
Mackintire Posted March 14, 2011 Share Posted March 14, 2011 My Ranger uses MUCH different tires - P245/75R16SL Just under $400 for a set of four Firestone Destination LE tires installed. I looked up what the heck "SL" means - agricultural use only. No wonder I couldn't find any in stock anywhere It's just got regular P245/75R16 installed now. This conversation on tires, so far, is the equivalent of which variation of malt-o-meal cereal tastes the best. So here is my constructive criticism: Go to www.tirerack.com and find your specific tires. After finding your specific tires Click on Surveys Then Click on: See a Full List of Survey Results for XXXXXXXXXXXXXXXX XXXXXXXXXXXXX Tires Consider purchasing anything in the top 33% of any category. So if there are 30 choices, choose something in the top 10. There is a ton of info available on tire at the tire rack you may find helpful. http://www.tirerack.com/tires/tiretech/tiretech.jsp http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=HAS Quote Link to comment Share on other sites More sharing options...
jc21 Posted March 23, 2011 Share Posted March 23, 2011 (edited) Probably going to have to buy tires for my Ranger in the next year or so. Size 225/70R14. These are getting hard to find. If you do find a store that carries them, they usually only have one model available. It's hard to believe there aren't more vehicles out there that use this size. Fourteen inchers are harder to find than previously but they are out there. Try Discount Tire or the previously mentioned Tire Rack ............ if they don't have 'em no one likely will. Edited March 24, 2011 by jc21 Quote Link to comment Share on other sites More sharing options...
jasonsadler10 Posted May 2, 2011 Share Posted May 2, 2011 Probably going to have to buy tires for my Ranger in the next year or so. Size 225/70R14. These are getting hard to find. If you do find a store that carries them, they usually only have one model available. It's hard to believe there aren't more vehicles out there that use this size. In the past with other vehicles ive always found that tire rack is good when noone else carries them. However shipping can get REALLLLLYYYYY expensive Good Luck Quote Link to comment Share on other sites More sharing options...
chucky2 Posted May 13, 2011 Share Posted May 13, 2011 I'd 2nd the suggestions of finding wheels in either 15" or 16" for your 14" wheeled Ranger (make sure to find out about backspacing and bolt concerns, should be plenty of info out there on sites like www.rangerpowersports.com and the like), and also, of going to TireRack and chosing the top tires in the categories. That being said, I've got an '03 FX4 Level II, auto, with the stock 15" wheels. Between the OE BFGoodrich All-Terrain KO's, Bridgestone Dueller A/T REVO's (in LT size, more tread depth than P rated - something to look at when buying any tire), and now the Firestone Destination A/T's, I like: The KO's the best for go anywhere'ness. The Destination A/T's the best for snow, ice, and water. I haven't had them in any mud yet. The REVO's were fine, better than the KO's when they were new, however after maybe 30k on them, they got much louder, didn't ride as nice, and had less performance. I'd say unless you're a mudder, if you want an A/T, the Destination A/T's are a good tire for the Ranger. Chuck Quote Link to comment Share on other sites More sharing options...
toddwxyz Posted May 27, 2011 Share Posted May 27, 2011 Probably going to have to buy tires for my Ranger in the next year or so. Size 225/70R14. These are getting hard to find. If you do find a store that carries them, they usually only have one model available. It's hard to believe there aren't more vehicles out there that use this size. ------ I just did, but guess I have 15" rims. Believe it or not, I had 105k miles on my 5-speed 3.0l Ranger on the original tires! Got Goodyear replacements at Walmart - good enough at this stage I suppose. Quote Link to comment Share on other sites More sharing options...
metalhead0523 Posted January 5, 2012 Share Posted January 5, 2012 So my girlfriend has a 2000 ranger, 3.0, auto, flex fuel, 4X4, extended cab. Truck has the factory sticker for 15 inch rims. We bought it from a small dealer last fall, has 16 inch aluminum rims. Speedometer is slightly off now, has P255/70R16 tires right now. I've been seeing P245/75R16 as common listings for tires on the rangers. Are they the correct size? If not what is the factory size? We just picked up a set of Dunlop AT20's that are P245/75R16 for $150 for all 4 with F150 steel rims. Were swapping the tires over regardless, but are they the right size? Thanks Quote Link to comment Share on other sites More sharing options...
