Sgt1411 Posted February 20, 2011 Share Posted February 20, 2011 Here's a list of the official TSB's so far....... http://www.explorerforum.com/forums/showthread.php?t=305964 Quote Link to comment Share on other sites More sharing options...
blwnsmoke Posted February 21, 2011 Share Posted February 21, 2011 Here's a list of the official TSB's so far....... http://www.explorerforum.com/forums/showthread.php?t=305964 link doesn't work.. looks like the site is down. Quote Link to comment Share on other sites More sharing options...
Sgt1411 Posted February 21, 2011 Author Share Posted February 21, 2011 link doesn't work.. looks like the site is down. Your right, site is down Quote Link to comment Share on other sites More sharing options...
Sgt1411 Posted February 21, 2011 Author Share Posted February 21, 2011 I copied the TSB's into a reply so you don't need to use the link in case it goes down again. 21737 2011 EXPLORER - CODES C1B00, U0131, U0100, U0001, U0121, AND/OR U0151 WHEN DIAGNOSING CODES C1B00, U0131, U0100, U0001, U0121, AND/OR U0151 ON 2011 EXPLORERS BUILT BEFORE 1/24/2011, CLEAR CODES AND WIGGLE TEST CONNECTER C139. IF CODES RETURN, BYPASS C139 FOR CIRCUITS VDB04 AND VDB05 USING THE SOLDER AND SHRINK TUBING METHOD FOUND IN SECTION 5 OF THE WIRING DIAGRAMS. THE CONCERN MAY BE INTERMITTENT AND ASSOCIATED WITH SPREAD TERMINALS AT PINS 24 AND 25. EFFECTIVE DATE: 02/11/2011 21735 MODULE SWAP PRACTICES FROM VEHICLE TO VEHICLE, MAY CREATE A NON-RECOVERABLE MODULE CONDITION FOR 2010-2011 VEHICLES AND SHOULD NOT BE ATTEMPTED. WHEN DIAGNOSING/REPAIRING MODULE RELATED CONCERNS ON 2010-2011 F-150, EDGE/MKX, F-SUPER DUTY, EXPLORER VEHICLES, SWAPPING A KNOWN GOOD MODULE FROM A DONOR VEHICLE IS NOT RECOMMENDED DUE TO THE ARCHITECTURE OF THE MODULE. SWAPPING A MODULE FROM A DONOR VEHICLE WILL CAUSE A MODULE ERROR DUE TO THE VIN RECORDED INSIDE THE MODULE OF THE DONOR VEHICLE. PLEASE ENSURE ALL WORKSHOP MANUAL PROCEDURES ARE FOLLOWED WHEN DIAGNOSING THE CONDITION PRESENTED, PRIOR TO ALL MODULE REPLACEMENTS. EFFECTIVE DATE: 02/09/2011 -------------------------------------------------------------------------------- 21725 2011 EXPLORER WITH AUTO PARK SCCM DTC C1B00 SOME 2011 EXPLORER VEHICLES BUILT ON OR BEFORE 1/18/2011 AND EQUIPPED WITH AUTO PARK MAY EXPERIENCE THE TRACTION CONTROL LIGHT COMING ON IF A TURN IS EXECUTED ABOVE 3 MPH (5 KPH) WITHIN 50 SECONDS OF STARTING THE VEHICLE. THE FOLLOWING FAULT CODES MAY ALSO BE SET: C1B00-08 IN THE STEERING COLUMN CONTROL MODULE (SCCM), C1B00-86 IN THE ANTILOCK BRAKE MODULE (ABS) MODULE FOR STEERING ANGLE SENSOR - SIGNAL INVALID, U0428-00 IN THE POWER STEERING CONTROL MODULE (PSCM) FOR INVALID DATA FROM STEERING ANGLE SENSOR MODULE (SASM), AND U0418-68 IN THE CRUISE CONTROL MODULE (CCM) FOR INVALID DATA RECEIVED FROM THE ABS MODULE. REPLACING THE SCCM MAY NOT RESOLVE THE CONDITION. ENGINEERING IS AWARE OF THE ISSUE AND A SOFTWARE UPDATE IS BEING DEVELOPED. CONTINUE TO MONITOR OASIS FOR UPDATES. EFFECTIVE DATE: 02/07/2011 21715 2011 EXPLORER DVD HEADREST INSTRUCTION INSERT WEBSITE NAVIGATION CLARIFCATION 2011 EXPLORER DVD HEADREST INSTRUCTION SHEET ON HOW TO FIND THE INSTALLATION INSTRUCTIONS ON THE ACCESSORIES WEBSITE. FOLLOW THE INSTRUCTIONS TO GET TO THE ACCESSORIES HOME PAGE. ONCE YOU ARE AT THE ACCESSORIES HOME PAGE, THE "RELATED LINKS" PULL DOWN IS LOCATED IN THE UPPER RIGHT CORNER OF THE WEB PAGE. CHOOSE "FORD LICENSED ACCESSORIES" AS DIRECTED. THE "INSTALLATION" LINK IS LOCATED AT THE BOTTOM OF THE PAGE BETWEEN THE "FAQ" AND "WARRANTY" LINKS JUST ABOVE THE FORD LOGO.. EFFECTIVE DATE: 02/02/2011 -------------------------------------------------------------------------------- 21716 2011 EXPLORER/EDGE/MKX HIGH LEVEL CLUSTER BLANKS OUT SOME 2011 EDGE, MKX, AND EXPLORER VEHICLES MAY EXPERIENCE THE LCD SCREENS ON THE BASE AND HIGH SERIES CLUSTER INTERMITTENTLY BLANKING OUT, AND THEN COMING BACK ON AFTER AN IGNITION KEY CYCLE. REPLACING THE INSTRUMENT CLUSTER WILL NOT CORRECT THE CONCERN. DO NOT ATTEMPT INSTRUMENT CLUSTER SERVICE FOR THIS CONDITION AS REPLACEMENT PARTS WILL FUNCTION IN THE SAME FASHION. ADVISE THE CUSTOMER THAT CYCLING THE IGNITION WHILE STOPPED AND IN 'PARK' WILL CLEAR THIS CONDITION AND RESTORE THE DISPLAY. IF THE ISSUE IS DIFFERENT THAN WHAT IS DESCRIBED ABOVE, CONTINUE WITH NORMAL DIAGNOSTICS. ENGINEERING IS AWARE OF THE ISSUE AND UPDATED CLUSTERS SHOULD BE AVAILABLE IN THE SECOND QUARTER OF 2011 TO ADDRESS THIS CONCERN. CONTINUE TO MONITOR OASIS FOR UPDATES. EFFECTIVE DATE: 02/02/2011 -------------------------------------------------------------------------------- 21711 2011 EXPLORER POWER LIFT GATE OPENING HEIGHT THE 2011 EXPLORER EQUIPPED WITH POWER LIFT GATE HAS A PROGRAMMABLE HEIGHT FEATURE THAT ALLOWS THE CUSTOMER TO SET THE OPENING HEIGHT OF THE POWER LIFT GATE. IF A CUSTOMER COMPLAINS THAT THE LIFT GATE DOES NOT OPEN ALL THE WAY, VERIFY THAT THE OPENING HEIGHT HAS NOT BEEN INADVERTENTLY PROGRAMMED TO A POSITION LOWER THAN EXPECTED. TO RESET THE OPENING HEIGHT TO FULL OPEN DO THE FOLLOWING: POWER OPEN THE LIFT GATE UNTIL IT STOPS. MANUALLY OPEN THE REST OF THE WAY TO THE 'FULL OPEN' POSITION. PRESS AND HOLD THE CONTROL BUTTON ON THE LIFT GATE UNTIL A CHIME IS HEARD, INDICATING THE NEW HEIGHT HAS BEEN PROGRAMMED. REFER TO THE 'DRIVER CONTROLS' SECTION OF THE OWNER GUIDE FOR ADDITIONAL INFORMATION. EFFECTIVE DATE: 02/01/2011 -------------------------------------------------------------------------------- 21706 KEY CODE NUMBER DOES NOT UNLOCK DOORS SOME 2011 EXPLORERS BUILT BETWEEN 11/1/2010 AND 1/24/2011 EQUIPPED WITH INTELLIGENT ACCESS WITH PUSH BUTTON START MAY EXHIBIT A KEYLESS ENTRY CODE LISTED ON THE KEY CARD THAT DOES NOT UNLOCK THE DOORS. THIS CAN OCCUR IF THE BCM (BODY CONTROL MODULE) IS REPLACED AND RFA (REMOTE FUNCTION ACTUATOR) MODULE IS NOT RESET. PRIOR TO RESETTING, VERIFY THAT THE KEYPAD IS FUNCTIONING PROPERLY BY PRESSING THE 7/8 AND 9/0 BUTTONS TO LOCK THE DOORS (MAKE SURE YOU HAVE A KEY OUTSIDE THE VEHICLE). IF DOORS DO NOT LOCK, FOLLOW NORMAL DIAGNOSTICS FOR INOP KEYPAD. TO RESET THE RFA KEY CODE AND PAIR THE NEW BCM KEYLESS ENTRY CODE TO THE RFA, FOLLOW THE WORK SHOP MANUAL PROCESS IN SECTION 501-14. THE KEYLESS ENTRY KEYPAD CODE RESET PROCEDURE IS FOUND ON THE SCAN TOOL UNDER TOOLBOX-BODY-SECURITY. EFFECTIVE DATE: 01/27/2011 -------------------------------------------------------------------------------- 21698 2011 EDGE/MKX AND EXPLORER - NAVIGATION - SD CARD FAULT SOME 2011 EDGE/MKX AND EXPLORER VEHICLES EQUIPPED WITH MY FORD TOUCH/MY LINCOLN TOUCH AND NAVIGATION MAY EXHIBIT AN (SD CARD FAULT) DISPLAYED IN THE UPPER RIGHT HAND VEHICLE DISPLAY SCREEN. ONLY NAVIGATION EQUIPPED VEHICLES REQUIRE SD CARDS AND A CARD MUST BE PRESENT FOR NAVIGATION FUNCTION. ENSURE THAT THE SD CARD LOCATED IN THE GLOVE COMPARTMENT WITH THE OWNER INFORMATION IS REMOVED AND INSTALLED. THE SD CARD IS INSERTED INTO THE MEDIA HUB AND SEATED WHEN A CLICK IS HEARD. PUSHING THE CARD AGAIN WILL RELEASE IT FOR REMOVAL, ACCIDENTAL BUMPING OF THE CARD WILL RELEASE IT CAUSING AN SD CARD FAULT ERROR MESSAGE ANYTIME THE CARD IS MISSING. NAVIGATION CAN NOT BE ADDED TO VEHICLES THAT ARE NOT ORIGINALLY EQUIPPED AND INSTALLING AN SD CARD IN NON-NAVIGATION VEHICLES WILL NOT ENABLE FUNCTION. EFFECTIVE DATE: 01/25/2011 -------------------------------------------------------------------------------- 21700 2011 EDGE/MKX/EXPLORER - INSTRUMENT CLUSTER - DIAGNOSTIC TROUBLE CODE (DTC) U0253 SOME 2011 EDGE/MKX AND EXPLORER VEHICLES EQUIPPED WITH MYFORD TOUCH/MYLINCOLN TOUCH MAY EXHIBIT DIAGNOSTIC TROUBLE CODE (DTC) U0253 STORED IN THE INSTRUMENT CLUSTER. IF THE INSTRUMENT CLUSTER TIME INFORMATION IS CONTINOUSLY DISPLAYED IN DASHES THEN FOLLOW WSM SECTION 413-01 PINPOINT TEST BA. IF NO INSTRUMENT CLUSTER TIME DISPLAY SYMPTOMS IN RIGHT HAND DISPLAY ARE PRESENT, DTC U0253 SHOULD BE IGNORED AND NO REPAIRS SHOULD BE PERFORMED. ENGINEERING IS INVESTIGATING CONCERN MONITOR OASIS FOR UPDATES. EFFECTIVE DATE: 01/25/2011 -------------------------------------------------------------------------------- 21695 (SERVICE TIP)- 2011 FORD EDGE/EXPLORER AND LINCOLN MKX WITH MISSING NAVIGATION APPLICATIONS 2011 FORD EDGE/EXPLORER AND LINCOLN MKX VEHICLES ORIGINALLY EQUIPPED WITH NAVIGATION MAY BE MISSING NAVIGATION AFTER A MYFORD TOUCH/MYLINCOLN SOFTWARE UPDATE. NAVIGATION MAY BE MISSING IF PROGRAMMING FAILED, NAVIGATION APPLICATION WAS NOT SELECTED, OR THE FINAL INTEGRATED DIAGNOSTIC SOFTWARE (IDS) SCAN TOOL SCREEN WAS NOT COMPLETED. ONCE THE USB FLASH DRIVE PROGRAMMING COMPLETES IN THE VEHICLE AND OK IS PRESSED ON THE VEHICLE SCREEN THE USB FLASH DRIVE MUST BE REMOVED FROM THE VEHICLE USB PORT AND INSERTING INTO THE SCAN TOOL AND OK, MUST BE SELECTED ON THE SCAN TOOL TO COMPLETE THE PROGRAMMING PROCESS. TO CORRECT THIS CONDITION IT WILL BE NECESSARY TO PERFORM A STANDARD ACCESSORY PROTOCOL INTERFACE MODULE (APIM) PROGRAMMING PROCEDURE FOLLOWING WORKSHOP MANUAL (WSM) SECTION 415-00 AGAIN AND MAKE SURE THE NAVIGATION APPLICATION IS SELECTED. EFFECTIVE DATE: 01/21/2011 -------------------------------------------------------------------------------- 21694 2011 EDGE/MKX/EXPLORER - ACCESSORY PROTOCOL INTERFACE MODULE REPLACEMENT (APIM) - PROVISIONING SOME 2011 EDGE/MKX AND EXPLORER VEHICLES EQUIPPED WITH MY FORD TOUCH/MY LINCOLN TOUCH MAY EXPERIENCE A PROVISIONING/PARSER ERROR AND NO PROGRAMMING ACTION WHEN INSERTING A USB FLASH DRIVE INTO THE VEHICLE MEDIA HUB, FOLLOWING WORKSHOP MANUAL(WSM) SECTION 415-00 FOR APIM MODULE REPLACEMENT PROCEDURE. IF USB FLASH DRIVE PROGRAMMING DOES NOT START SHORTLY AFTER INSERTING THE USB DRIVE, REMOVE THE FLASH DRIVE AND RE-INSERT IT INTO THE MEDIA HUB. A PROVISIONING AND/OR PARSING FAILED ERROR WILL BE PRESENT AND THREE ICON/TABS WILL BE DISPLAYED ON THE SCREEN. SELECT SYNC APPS, INSTALL APPLICATION/UPDATES, BEGIN SOFTWARE INSTALLATION, AND SELECT YES FOR BEGIN INSTALLATION. ONCE COMPLETE THE VEHICLE DISPLAY WILL REMAIN UNCHANGED, REMOVE THE USB FLASH DRIVE, INSERT IT INTO SCANTOOL THEN PRESS OK ON THE SCANTOOL. EFFECTIVE DATE: 01/20/2011 -------------------------------------------------------------------------------- 21664 2011 EXPLORER - EXITING TRANSPORT MODE 2011 EXPLORER VEHICLES ARE DELIVERED IN BATTERY SAVER TRANSPORT MODE. A MESSAGE MAY APPEAR IN THE CLUSTER MESSAGE CENTER, STATING VEHICLE IS IN TRANSPORT MODE. EXITING TRANSPORT MODE IS LISTED AS STEP 7 ON THE 2011 FORD EXPLORER PRE-DELIVERY SERVICE RECORD AND SHOULD BE PERFORMED JUST PRIOR TO CUSTOMER DELIVERY. TO EXIT TRANSPORT MODE THE IGNITION MUST BE IN RUN WITH ENGINE OFF, PRESS BRAKE PEDAL 5 TIMES AND PRESS HAZARD SWITCH 4 TIMES (ON, OFF, ON, OFF) WITHIN 10 SECONDS. IF NOT MANUALLY EXITED, TRANSPORT MODE WILL AUTOMATICALLY TURN OFF AFTER THE VEHICLE IS DRIVEN 75 MILES. NOTE: VEHICLES WITH PUSH BUTTON START CAN ACHIEVE IGNITION RUN MODE BY DEPRESSING THE START BUTTON TWICE WITHOUT DEPRESSING THE SERVICE BRAKE PEDAL. EFFECTIVE DATE: 12/21/2010 Quote Link to comment Share on other sites More sharing options...
gregross Posted March 10, 2011 Share Posted March 10, 2011 Does anyone know if your vehicle is built after the TSB date whether the fixes are in your truck? Quote Link to comment Share on other sites More sharing options...
