HalH1 Posted July 25, 2009 Share Posted July 25, 2009 OK, electrical gremlin question for all the Nav owners or experts out there... My font seat power mirror and pedal fuse (30A) as begun blowing regularly. 1st was mysterious and did no new equipment installs or mods to cause a short. Replaced it with an OEM fuse, and it popped again about 2 weeks later. Any ideas of the a possible culprit or how to figure this one out? As always, any help is appreciated. Quote Link to comment Share on other sites More sharing options...
Buzzforbrains Posted July 27, 2009 Share Posted July 27, 2009 OK, electrical gremlin question for all the Nav owners or experts out there... My font seat power mirror and pedal fuse (30A) as begun blowing regularly. 1st was mysterious and did no new equipment installs or mods to cause a short. Replaced it with an OEM fuse, and it popped again about 2 weeks later. Any ideas of the a possible culprit or how to figure this one out? As always, any help is appreciated. Takes two weeks to pop? Does it happen under any specific conditions? I would buy some fuses, put a new one in, work the mirrors, then work the chair, etc. If it pops while doing one of those you have narrowed it down. Plug and unplug the wire harness you can get too, maybe a bad connection. Quote Link to comment Share on other sites More sharing options...
HalH1 Posted August 2, 2009 Author Share Posted August 2, 2009 Takes two weeks to pop? Does it happen under any specific conditions? I would buy some fuses, put a new one in, work the mirrors, then work the chair, etc. If it pops while doing one of those you have narrowed it down. Plug and unplug the wire harness you can get too, maybe a bad connection. Thanks, I will try that. I had just replaced the side molding that holds the seat controls but was pretty sure thsoe were plugged in well. Controls were working fine. A hunting for the Gremlin I will go... Quote Link to comment Share on other sites More sharing options...
